That did the trick, good looking out
--- In xl7@yahoogroups.com, erik_magrini@B... wrote:
> Not sure if the XX-7's are like this, but I know my old 505 used to
be, so
> it's just a guess. If it's set to "off", basically it's ignoring
the the
> Program changes imbedded in the Pattern, so it just keep whatever
Preset
> is on that channel for all Pattern. Again, this might not be it,
but it
> sounds like it to me.
> rEalm
> "Soul Brother #1" <solbro_1_2000@y...>
> 03/18/2004 11:21 AM
> Please respond to xl7
> To: xl7@yahoogroups.com
> cc:
> Subject: [xl7] Re: patttern preset problems
> ok I will be sure to check that out, if it isn't on "on", what is
it
> causing it to do??
> > In your midi menu, make sure that "receive program change" is on.
> > rEalm
> > 03/18/2004 09:28 AM
> > cc:
> > Subject: [xl7] patttern preset problems
> > I have the mp-7, I have had it a couple of weeks. I am having
> > problems with presets being the same on each track, on all of my
> > saved patterns. If I go thru each pattern & tracks even for
factory
> > saved patterns, all the presets are the same for each track on
> every
> > pattern. So if I have patterns A,B,C with tracks 1,2,3...pattern
A
> > track 1 will have the same preset as pattern B track 1, and so on.
> > Even if I go thru and change the preset on a certain track on a
> > pattern, and save...when I turn it off and turn it back on I have
> the
> > same problem...what am I doing wrong??
> > Yahoo! Groups Links
> > The information transmitted is intended only for the person(s)or
> entity
> > to which it is addressed and may contain confidential and/or
> legally
> > privileged material. Delivery of this message to any person other
> than
> > the intended recipient(s) is not intended in any way to waive
> privilege
> > or confidentiality. Any review, retransmission, dissemination or
> other
> > use of , or taking of any action in reliance upon, this
information
> by
> > entities other than the intended recipient is prohibited. If you
> > receive this in error, please contact the sender and delete the
> > material from any computer.
> > For Translation:
> > http://www.baxter.com/email_disclaimer
> > [Non-text portions of this message have been removed]
entity
legally
than
privilege
other
> use of , or taking of any action in reliance upon, this information
by
> For Translation:
