Hi all !
I'm brand new to this newsgroup and very happy that I found a very
active XL-7 group. =)
I would like to have a song loop feature. Then I would be able to
build up a background track for live performance.
It also seems that you cannot route incoming MIDI signals to the
output ports A and B if you set MIDI IN to B. That's bad, because if
I want to use the factory patterns (which are set to MIDI A) and
play the XL-7 (and other gear through it which is synced to the XL-
7) with an external keyboard, I always play the XL-7 presets with
it. :(((
Greetings,
Ronald
--- In xl7@yahoogroups.com, erik_magrini@B... wrote:
> I'll add one more. If you're using the Track mute buttons
as "note"
> controllers, you should be able to use the Edit+track mute combo
to go to
> that channel directly, same as with the regular track mute mode.
Damn,
> that didn't make any sense did it....
> rEalm
> "Leo Cavallo" <leocavallo@g...>
> 03/13/2004 08:47 AM
> Please respond to xl7
> To: xl7@yahoogroups.com
> cc:
> Subject: [xl7] New OS feature ideas
> hi list, Erik and Aaron
> my most importat feature request for a new OS would be:
> - being able to move through bars indipendently from playback,
when in
> step
> recording mode.
> the chance to use the 16 knobs to change the pitch for every step
of the
> bar would be a nice addon too. back to analog sequencing days...
it would
> be great for drums programming too (where each note is related to
a
> different instrument in the drum kit)...
> thanks
> leocavallo
> www.groundloops.com
> The information transmitted is intended only for the person(s)or
entity
> to which it is addressed and may contain confidential and/or
legally
> privileged material. Delivery of this message to any person other
than
> the intended recipient(s) is not intended in any way to waive
privilege
> or confidentiality. Any review, retransmission, dissemination or
other
> use of, or taking of any action in reliance upon, this information
by
> entities other than the intended recipient is prohibited. If you
> receive this in error, please contact the sender and delete the
> material from any computer.
> For Translation:
> http://www.baxter.com/email_disclaimer
