Digital XL7 and SP808
2002-01-17 by shredbabe
I want to digitally record from the XL7 (out SPDIF) and from a CD-
player (digital out).
And also playback digitaly from the SP808 and record to the digital
in of the Philips dual player/burner.
Is this possible with the OP1 board?
Richard
Re: [xl7] Digital XL7 and SP808
2002-01-17 by erik_magrini@Baxter.com
You mean you want to record all three at once digitally?  I don't think
you'd be able to do that with the OP1.  It's been awhile since I used my
Sp808, but you could route the CD player and the XL-7 into the sp808 via
regular analog cables, and then connect the digital out of the sp808 into
the CD Burner.  The sp808 list is your best bet for this question.
BTW, did you know you can upgrade your 808 into the EX version for free?
The OS from the EX version works just fine in the reguler 808, and you can
swap out the internal 100MB Zip drive for a 250MB one too!
"shredbabe" <itexpert@...>
01/17/02 03:08 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Digital XL7 and SP808
Richard
Re: Digital XL7 and SP808
Thanks, but I bought the Ex (just because of the colors....).
I ask the question the 808 list.
Regards!
think
used my
sp808 via
sp808 into
free?
you can
> rEalm
> "shredbabe" <itexpert@y...>
> 01/17/02 03:08 AM
>         To:     xl7@y...
>         cc:
> Hi,
> Regards,
> Richard
> xl7-unsubscribe@y...
Re: [xl7] Re: Digital XL7 and SP808
2002-01-17 by www.mp3.com/koering
how many samples can the sp808 or Ex play???? thought to bought one... would
have to sell my ESI32...
To: <xl7@yahoogroups.com>
Sent: Thursday, January 17, 2002 2:06 PM
Subject: [xl7] Re: Digital XL7 and SP808
> Regards!
> think
> used my
> sp808 via
> sp808 into
> free?
> you can
> > rEalm
> > 01/17/02 03:08 AM
> >         To:     xl7@y...
> >         cc:
> > Hi,
> > Regards,
> > Richard
Where did you get anything about erasing and formating Zips from my post?
Not sure I understand what you mean.  Do you mean performing a full erase
on a 100MB disk inserted into a 250MB drive?  I worked for 4 months with
an "User Installed" 250 drive in my sp808, and I still used my 100MB disks
just fine.  They were perfectly functioning, even with Full Erase
operations.
This is not entirely the case.
Performing a 'full erase' on a 100 meg disk will destroy the disk. You can
'quick format' only.
However, upgrading your disk to the 250 one (or >any< ide sized drive,
removable or not) is really cheap right now.
2002-01-17 by Jonathan El-Bizri
Performing a 'full erase' on a 100 meg disk will destroy the disk. You can 'quick format' only.
However, upgrading your disk to the 250 one (or >any< ide sized drive, removable or not) is really cheap right now.
Sent: Thursday, January 17, 2002 4:47 AM
Subject: Re: [xl7] Digital XL7 and SP808
You mean you want to record all three at once digitally? I don't think you'd be able to do that with the OP1. It's been awhile since I used my Sp808, but you could route the CD player and the XL-7 into the sp808 via regular analog cables, and then connect the digital out of the sp808 into the CD Burner. The sp808 list is your best bet for this question.
BTW, did you know you can upgrade your 808 into the EX version for free? The OS from the EX version works just fine in the reguler 808, and you can swap out the internal 100MB Zip drive for a 250MB one too!
"shredbabe"
01/17/02 03:08 AM
cc:
Richard
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Access Your PC from Anywhere
It's Easy. It's Fast. - Free Download
http://us.click.yahoo.com/yWCYWA/6XkDAA/ySSFAA/pWZylB/TM
Actually, I was refering to 'full erase' using a 100 meg zip drive (the original kind), using the upgraded. If you replace the drive with the 250 version, then your 808 becomes identical to the EX model.
Sent: Thursday, January 17, 2002 10:17 AM
Where did you get anything about erasing and formating Zips from my post? Not sure I understand what you mean. Do you mean performing a full erase on a 100MB disk inserted into a 250MB drive? I worked for 4 months with an "User Installed" 250 drive in my sp808, and I still used my 100MB disks just fine. They were perfectly functioning, even with Full Erase operations.
