MIDI backwash
MIDI backwash
2004-02-23 by S V G
Greetings,
     My MIDI layout is:  Kurzweil PC2X keboard MIDI out --> XL-7 MIDI in.  No return MIDI cable is
in place.
     The other day I was playing some patterns on my XL-7.  Returning to my default mode which is
how I control the sounds from my Kurzweil keyboard, I found that the Kurzweil was buggered.  It
couldn't change programs, or only in a limited way.  Powering down and then back again fixed it.
The question is: how could this have happened?  Is there the possibility of a small voltage or
something travelling backwards on a MIDI cable and fugging with the master controller?  This is
the only way the two instruments are connected, other than through a common ground at the mixer.
     Not a problem at all, just a little confused.
        Stephen
Do you Yahoo!?
Yahoo! Mail SpamGuard - Read only the mail you want.
http://antispam.yahoo.com/tools
RE: [xl7] MIDI backwash
2004-02-23 by patrick a thomas
Check your OS on the Kurz.  I remember having a similar problem with ours.
Once I updated the OS, the problem ceased.
Find it at this website if you don't have it already.
www.kurzweilmusicsystems.com  Look under PC2 Downloads
Rev P
  Sent: Monday, February 23, 2004 12:44 PM
  Subject: [xl7] MIDI backwash
       Greetings,
  in place.
controller?  This is
          Stephen
  Do you Yahoo!?
        Yahoo! Groups Sponsor
              ADVERTISEMENT
  Yahoo! Groups Links
    a.. To visit your group on the web, go to:
    b.. To unsubscribe from this group, send an email to:
    c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
RE: MIDI backwash
2004-02-24 by S V G
Thanks, I have the latest OS update already (ver 3.10).  There is not a problem with either
the Emu or the Kurz.  The question is rather "Is it possible for information to travel backwards
on a MIDI cable that is hooked up to the MIDI OUT on my Kurzweil?"
     Stephen
<<Check your OS on the Kurz.  I remember having a similar problem with ours.
Rev P>>
Do you Yahoo!?
