Simple, but great tips, thanks!
--- In xl7@y..., erik_magrini@B... wrote:
> - is there any way to delete a pattern, so that is says "Empty
Sequence"
> again?
> >>>Nope, you need to select an empty pattern (see the next comment
below),
> then resave it to that location. <<<
> - is there any way to start the XL7 with a pattern of choice after
> rebooting? I always want to start with an empty pattern and after
creating
> save it in another place.
> >>>Only if you put it in User Bank 0, Pattern 0. I put my
default "Empty
> Pattern" there actually, so the XL-7 always boots to a fresh
start. That
> way if you need to reinitialize the pattern, it's easy to select a
blank
> one. Just crank the wheel to the right hard, and it'll jump to the
first
> pattern, in this case the empty one.
> Another tip:
> Organizing your patterns is really easy on the XL/MP-7's, since you
have
> so many banks to choose from. For me, it's best to catagorize my
patterns
> by genre and save them accordingly. For instance, Breaks in Bank
0,
> Trance in Bank 1, DnB in Bank 2, Ambient in Bank 3, etc. This is
great if
> you play out live too, because you can change your sets predictably
> depending on the mood of the crowd, and you know that as long as
you
> select the next pattern from the same bank, it'll fit together.<<<
> rEalm
