Archive for xl7.
HELP! popping sound every r bars or so during certain songs...
2004-02-22 by flaviotronic
its like, right now, i have a beat going that has 2 tracks useing
plk sounds, drums bass other sounds blahblah, but when i put the plk
tracks on popping sounds pop up every few bars, is there a way to
stop this? any help would be MUCH apprechiated, thanks
Re: [xl7] HELP! popping sound every r bars or so during certain songs...
2004-02-22 by Wesley D
I'm glad someone else other than me brought this up.  I've been through HELL with pops and clicks on my EMU, which isn't to say I don't love the thing, but damn, it pops like crazy sometimes.
ONe thing it might be, if you're using an external clock, and long delay times, you get the jitter effect.  I don't really think too much can be done about this.  Even volume envelopes that rely on tempo, if you watch your tempo indicator it jumps around, up down, dead on, back and forth, it's constantly updating.
Other things that introduce pops I've found:  Using solo mode.  Dunno why, but with sub bass it introduces a killer pop on the attacks.  Also, check sample start times, and volume envelopes.  Depending on the patch adjusting start times can cause a pop.  with the volume, just watch out for too quick of a jump either in the attack or decay.
I'd love to hear other remedy's, and possible problem parameters.  It sure does suck to work on a sound, and then find out that in some stage of your programming you made it start popping.
OH yes, you said every couple bars, is it right when the loop loops back around?  That could be it, if you've got notes that are longer than your loop the sudden drop could be popping.  could also be doubling up on attacks if a previous note didn't receive its' note-off message.
hope some of that can help, and you're not alone, I still struggle with this from time to time.
-Wesley
Do you Yahoo!?
Yahoo! Mail SpamGuard - Read only the mail you want.
Re: HELP! popping sound every r bars or so during certain songs...
2004-02-23 by dj 61
There has beeen a thread about this before. Particularly with some
of the p. drum presets. It was determined that this is usually
resultant of a particular filter and its settings. Ibe lieve it is
called megasweep or something along that line. I have had popping
before with non-p.drum presets. The most recent, last fall, I was
using that filter on I know for shure. Oddly enough I was able to
correct it by a severe reduction of tracks in the key areas. This of
course altered the nature of my track, but oh well. Now we have
learned that this can usually be overcome by adjusting the filter
settings or just using a different filter all together. The thread
on it was only a month or two ago; I think it was called px-7
popping or something like that. Hope this helps. Maybe try muting
different tracks to narrow down which presets it happens on then
check the filters.
I hope this helps.
   61
plk
