data wheel malfunction
2004-02-19 by Nermin
Archive for xl7.
Hi everyone.For a while I've had this problem with data wheel on my xl7 where it would throw data all over the place unless turned really slowly.I've tried deoxidizer but that would work anly for a day and it just comes back to same problem.I would really like to fix this somehow.Does anyone else have this problem and can it be fixed easily? Thanks Nermin
2004-02-19 by Aaron Eppolito
Pretty much everyone has this problem. The encoders suck. If you're brave, you could bend back the four little pins that hold the encoder together and try and improve the wiper contacts, but you'll probably end up making it worse. -Aaron --- Nermin <extra_mayo79@...> wrote: > For a while I've had this problem with data wheel on my xl7 __________________________________ Do you Yahoo!? Yahoo! Mail SpamGuard - Read only the mail you want. http://antispam.yahoo.com/tools
2004-02-19 by khjkkkkk khjkhjk
Well, that sucks.I guess I am gonna have to keep turning it really slowly and get used to that. I am not gonna mess with internals becouse I am usually not very lucky with that kinda stuff. thanks Nermin Aaron Eppolito <synthesis77@...> wrote: Pretty much everyone has this problem. The encoders suck. If you're brave, you could bend back the four little pins that hold the encoder together and try and improve the wiper contacts, but you'll probably end up making it worse. -Aaron --- Nermin <extra_mayo79@...> wrote: > For a while I've had this problem with data wheel on my xl7 __________________________________ Do you Yahoo!? Yahoo! Mail SpamGuard - Read only the mail you want. http://antispam.yahoo.com/tools --------------------------------- Yahoo! Groups Links To visit your group on the web, go to: http://groups.yahoo.com/group/xl7/ To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- Do you Yahoo!? Yahoo! Mail SpamGuard - Read only the mail you want. [Non-text portions of this message have been removed]
2004-02-19 by vibesart
Search thru the archive......like many moons ago someone said they used heavy bicycle-grade grease loaded down into encoder mechanism - they swore that it "fixed" the problem remember - I am not saying to do this - I am saying that I think I remmber someone saying that... rEalm? Any memories of this? --- In xl7@yahoogroups.com, khjkkkkk khjkhjk <extra_mayo79@y...> wrote: > Well, that sucks.I guess I am gonna have to keep turning it really slowly and get used to that. I am not gonna mess with internals becouse I am usually not very lucky with that kinda stuff. > thanks > Nermin > > Aaron Eppolito <synthesis77@y...> wrote: > Pretty much everyone has this problem. The encoders suck. If you're > brave, you could bend back the four little pins that hold the encoder > together and try and improve the wiper contacts, but you'll probably > end up making it worse. > > -Aaron > > --- Nermin <extra_mayo79@y...> wrote: > > For a while I've had this problem with data wheel on my xl7 > > __________________________________ > Do you Yahoo!? > Yahoo! Mail SpamGuard - Read only the mail you want. > http://antispam.yahoo.com/tools > > > --------------------------------- > Yahoo! Groups Links > > To visit your group on the web, go to: > http://groups.yahoo.com/group/xl7/ > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > --------------------------------- > Do you Yahoo!? > Yahoo! Mail SpamGuard - Read only the mail you want. > > [Non-text portions of this message have been removed]
in all of the free time you must have, Aaron :0 - sys rev suggestion, the fabled dead-encoder work-around: playpads-as-numeric-keypad mode: C-A as 0-9, A#-B as (+) and (-) and top C as ENTER I know this is probably not practical to suggest, but I am curious - is it possible given the archetecture of the Command Station? my wheel is starting to go too......causes me great distress as I use the box all the time ok - thanks Ed --- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@y...> wrote: > Pretty much everyone has this problem. The encoders suck. If you're > brave, you could bend back the four little pins that hold the encoder > together and try and improve the wiper contacts, but you'll probably > end up making it worse. > > -Aaron > > --- Nermin <extra_mayo79@y...> wrote: > > For a while I've had this problem with data wheel on my xl7 > > __________________________________ > Do you Yahoo!? > Yahoo! Mail SpamGuard - Read only the mail you want. > http://antispam.yahoo.com/tools
2004-02-20 by Stu
Have a look at this link: http://www.jsigle.com/musicol/emufix.htm Stu -----Original Message----- From: vibesart [mailto:edmann@...] Sent: 19 February 2004 22:15 To: xl7@yahoogroups.com Subject: [xl7] Re: data wheel malfunction in all of the free time you must have, Aaron :0 - sys rev suggestion, the fabled dead-encoder work-around: playpads-as-numeric-keypad mode: C-A as 0-9, A#-B as (+) and (-) and top C as ENTER I know this is probably not practical to suggest, but I am curious - is it possible given the archetecture of the Command Station? my wheel is starting to go too......causes me great distress as I use the box all the time ok - thanks Ed --- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@y...> wrote: > Pretty much everyone has this problem. The encoders suck. If you're > brave, you could bend back the four little pins that hold the encoder > together and try and improve the wiper contacts, but you'll probably > end up making it worse. > > -Aaron > > --- Nermin <extra_mayo79@y...> wrote: > > For a while I've had this problem with data wheel on my xl7 > > __________________________________ > Do you Yahoo!? > Yahoo! Mail SpamGuard - Read only the mail you want. > http://antispam.yahoo.com/tools Yahoo! Groups Links
2004-02-20 by erik_magrini@Baxter.com
Yeah, vaguely remember it, but I wouldn't recommend it though. Probably will help things for a bit, but I can't imagine grease is going to help in the long run, might make things worse. The only other option I can suggest, is contact Emu tech suport and see how much it would cost to get a new encoder installed. rEalm Search thru the archive......like many moons ago someone said they used heavy bicycle-grade grease loaded down into encoder mechanism - they swore that it "fixed" the problem remember - I am not saying to do this - I am saying that I think I remmber someone saying that... rEalm? Any memories of this? --- In xl7@yahoogroups.com, khjkkkkk khjkhjk <extra_mayo79@y...> wrote: > Well, that sucks.I guess I am gonna have to keep turning it really slowly and get used to that. I am not gonna mess with internals becouse I am usually not very lucky with that kinda stuff. > thanks > Nermin > > Aaron Eppolito <synthesis77@y...> wrote: > Pretty much everyone has this problem. The encoders suck. If you're > brave, you could bend back the four little pins that hold the encoder > together and try and improve the wiper contacts, but you'll probably > end up making it worse. > > -Aaron > > --- Nermin <extra_mayo79@y...> wrote: > > For a while I've had this problem with data wheel on my xl7 > > __________________________________ > Do you Yahoo!? > Yahoo! Mail SpamGuard - Read only the mail you want. > http://antispam.yahoo.com/tools > > > --------------------------------- > Yahoo! Groups Links > > To visit your group on the web, go to: > http://groups.yahoo.com/group/xl7/ > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > --------------------------------- > Do you Yahoo!? > Yahoo! Mail SpamGuard - Read only the mail you want. > > [Non-text portions of this message have been removed] Yahoo! Groups Links The information transmitted is intended only for the person(s)or entity to which it is addressed and may contain confidential and/or legally privileged material. Delivery of this message to any person other than the intended recipient(s) is not intended in any way to waive privilege or confidentiality. Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by entities other than the intended recipient is prohibited. If you receive this in error, please contact the sender and delete the material from any computer. For Translation: http://www.baxter.com/email_disclaimer [Non-text portions of this message have been removed]
Whoa!!! That's awesome, how'd you find that? I think with some pictures
that are geared towards the XX-7, this would be very easy for most people
to do.
Stu <routerman@...>
02/19/2004 06:11 PM
Please respond to xl7
cc:
Subject: RE: [xl7] Re: data wheel malfunction
Stu
top C as ENTER
ok - thanks
Ed
> -Aaron
> Do you Yahoo!?
Yahoo! Groups Links
Yahoo! Groups Links
For Translation:
[Non-text portions of this message have been removed]2004-02-20 by Stu
It was on the emusaic.net E-MU sampler mailing list a while back. Altho my
mp-7 is fine, my E-MU Ultra suffers from this problem. It don't really
bother me tho coz I have an ASCII keyboard plugged into it and use that most
of the time.
Glad I could be of some help, tho the real credit should go to the guy who
made the webpage!
Stu
Sent: 20 February 2004 12:59
to do.
Stu <routerman@...>
02/19/2004 06:11 PM
cc:
Stu
top C as ENTER
ok - thanks
Ed
> -Aaron
> Do you Yahoo!?
Yahoo! Groups Links
Yahoo! Groups Links
For Translation:
Yahoo! Groups Links
