Multisetup
2002-01-15 by erik_magrini@Baxter.com
I thought all Multisetup changes WERE saved, until a new multi is loaded. Is this new? rEalm When you press the Stop button twice it forces a send of all the 'setup' info that is at tick 0 (MultiSetup settings etc.). If it is setting external things not the way you want, it sounds like your MultiSetup is not set correctly for what you want to happen. When you make changes to your MultiSetup you will have to Save it, otherwise it will not be the same the next time you power up.
