Single notes without sound - why?
2002-01-15 by heinrich22001
Hi, can somebody here explain this, I went through the whole manual and the addendums but did not find an answer. I recorded a mididrumfile from cakewalk sonar on track 1 of the mp-7. It contained - besides the kick, snare and some percussion - a hihat and cymbal pattern with 16th. The file is definitely not overloading the track, thers not much happening. Quantize during recording was set to "off". Playing back the unrecorded file was no problem at all. But after I recorded it, there are notes of the hihat pattern without sound. On some part of the pattern only one. On other parts more. No matter how often I tried this - allways the same notes do not sound. When I play back the recorded file very slowly I realize, the midi note seems to be there (or was it just a controller event?), because I can see the green light on, but the sound of this note is missing. I altered the quantize setting when I was playing back the file from 16 to 32. But still the same. I changed the preset kits - still the same problem. Is it a bug? I don“t think so, because its so "regular". Did I miss something? Any help is appreciated. I spent a lot of time last night in solving this. Heinrich
