PX-7 Slowdown (I got it too now!)
2004-02-17 by erik_magrini@Baxter.com
Damn, the same day I said I hadn't really seen this, I run into it later that night big time. I was working on a new downtempo pattern, and all of a sudden everything got super sluggish on me. At first, there was about a 2 second pause between my actions and what the screen said. Eventually the more I played with this, the longer the pause got until it was closer to 10 seconds lag! The weird thing is, it only happens on this one pattern (using ONLY the Studio Kit Preset too), if I go to another pattern, everything was instantly fine. If I powered off/on and came back to this same pattern, eventually it would start again. I've put the Pattern file here in case anyone can test this on their PX-7 (or XX-7 with Drum ROM): http://launch.groups.yahoo.com/group/xl7/files/Command%20Station%20Data/ It's called "No Control" and will load by default to Pattern Bank 1:001. I'd appreciate it if anyone can check this one out, as it's only happening with this pattern, and I want to return my PX-7 if I'm the only one with this problem (aside from the original poster). I didn't get a chance to see if it was just the preset causing this, as it didn't rear it's ugly head until I was ready for bed :) To try and solve this, I deleted all sysex, controller, and aftertouch info from the pattern thinking maybe that would help (it didn't). There were no stuck notes either. rEalm ------------------------ Hello, I bought my PX7 last week because of the hype of the blow out at Guitar Center. I plan to sequence my synths with it, and make some beats. Has anyone recorded a patterm and while twirling the control knobs experience the PX7 slowing down. There was a major lag time when you hit the button switching the mode from quick edit to volume to pan. You could hit the button several times fast and it would take a few seconds for the switch to occur. Has this happened with anyone else, or is there something wrong with my machine? The information transmitted is intended only for the person(s)or entity to which it is addressed and may contain confidential and/or legally privileged material. Delivery of this message to any person other than the intended recipient(s) is not intended in any way to waive privilege or confidentiality. Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by entities other than the intended recipient is prohibited. If you receive this in error, please contact the sender and delete the material from any computer. For Translation: http://www.baxter.com/email_disclaimer [Non-text portions of this message have been removed]
