Index last updated: 2026-04-03 18:22 UTC
Re: [xl7] 12 hous of work and another thing i cant record due tothe bugs.
2002-01-14 by Aaron Eppolito
Alex Jacobi wrote:
> Does anybody know a way how to make the mp7 not save this data intially to
> the pattern, or a way to edit this tick 0?
Set the track to external and it will not save the initial state.  Note however, if
it is already there (i.e. you saved it once with "int" or "both") this will not
erase it.  In that case you have to delete them with the erase events command (like
you already suggested).
-Aaron
2002-01-22 by Sean Wilhelmsen
Alex Jacobi wrote:
> > Von: Scott Ruda <scottr@...>
> > Antworten an: xl7@yahoogroups.com
> > Datum: Sun, 13 Jan 2002 23:30:46 -0800
> > An: xl7@yahoogroups.com
> > Betreff: Re: [xl7] 12 hous of work and another thing i cant record
> due to the
> > bugs.
> >> It changes all the fx routings on my E5000 each time i press stop
> >> twice.
> > When you press the Stop button twice it forces a send of all the
> 'setup'
> > info that is at tick 0 (MultiSetup settings etc.). If it is setting
> > external things not the way you want, it sounds like your MultiSetup
> is
> > not set correctly for what you want to happen. When you make changes
> to
> > your MultiSetup you will have to Save it, otherwise it will not be
> the
> > same the next time you power up. Once you play the pattern once,
> there
> > is a presumption that there is no need to send that setup info the
> next
> > time it loops or you just want to Play because things are already
> set
> > up, so it is not sent.
> I\ufffdve had the same problem with my E4x, here\ufffds a workaround, delete all
> control 79 and 80 in your pattern. Control 79 (or 80, i don\ufffdt
> remember)
> switches the output assignment in  your sampler.
> intially to
> >> Sticking notes are happening all the time.  Like evry time i run
> the
> >> patterns i am working on and the seem to stick and un stick at
> will.
> >Can you isolate on any other info that correlates to when this
> happens?
> >Do you have a pattern that does it all the time? If so, send it to me
> >and I will investigate it.
> I have the same problem, it happens only in some patterns, that some
> notes
> play sometimes and sometimes not, it\ufffds always the same note
> Alex
Make sure when using external gear you set up the those tracks' status
immediately to external. The second you record something into a XL-7 on
that track and the track status is set to both or internal, the Program
Change, Arp status, Volume, Pan and Mix status will be recorded onto
tick 0 of that track. If you forget, you'll need to do what Alex has
suggested and delete that information.
sean at e-mu / ensoniq
2002-01-22 by Alex Jacobi
> Von: Sean Wilhelmsen <seanw@...>
> Antworten an: xl7@...m
> Datum: Tue, 22 Jan 2002 09:44:13 -0800
> Betreff: Re: [xl7] 12 hous of work and another thing i cant record due tothe
> bugs.
But what, if i send my patterns via e-loader into the mp7( i usually do
that)? Afaik the mp7  doesn´t set them to external and i have to delete them
manually.
