SPDIF signal enhancers
2004-02-11 by erik_magrini@Baxter.com
To be honest, there's really no need to use one (I don't think they even
exist).  Even though the signal is quiet, you can still normalize it to a
hotter level and have it be cleaner than any analog signal you can record
from the XX-7.  The only area that the quiet signal is bothersome IMO is
when you're overdubbing into another sequencer and the other tracks are
significantly louder.  It can be a pain to hear what you're trying to add,
no?   In this case, it's best to just turn down the other tracks until
you're done recording, and then normalize the new XX-7 part.
BTW, if you EVER normalize a digital signal, regardless of if it's the
XX-7 or anything else, NEVER normalize to 0dB!!!!  There's some very valid
reasons for this, mainly that some DAC's will actually create a signal
that clips from intersample modulations it perceives as greater than 0dB!.
 Sounds impossible, but it's a well known fact.  If you need to normalize
a track, I recommend always normalizing no higher than -2dBFS.  Same thing
applies when you're doing a final mix or master on a DAW, the final file
should never be higher than -0.5dBFS.  Any hotter, and some CD players
will actually clip the signal resulting in subtle, but noticeable
distortion.
Just an FYI.
The S/PDIF signal isn't suffering from any hum. It's just weak. Does
anybody know if there are any signal enhancers for this problem?
Maik
use of, or taking of any action in reliance upon, this information by
material from any computer.
For Translation:
Re: SPDIF signal enhancers
2004-02-11 by vibesart
Yo rEalm -
another POV on this (my own, altho I am not glued to this method...)
the quality of Normalization does depend on the software that is being
used to Normalize, and of course we all know that in the N process the
audio takes a hit, so to a degree one has to weigh which hit they
prefer - N or A/D.
I find myself continually more drawn to an analog re-recording of the
XL7 - and have not found noise to be an issue. For me the analog
re-recording gives synths a bit more definition and I do like the
sound of the Emu D/A's - but of course this method does require good
A/D's and a mixer or mic pre or other signal booster, and it does add
a coloration of the orginal sound.
That said - depending on what DAW software is being used one should be
able to boost the XL7 spdif signal before/during the recording.
I hear time and again that the optimum place to aim for in a 24 bit
recording of individual tracks is -6 db (Bob Katz, the Metric Halo
guys et al), for whatever that is worth.
rock forward
Ed
even
to a
record
IMO is
to add,
valid
0dB!.
normalize
thing
file
> distortion.
> Just an FYI.
> rEalm
> Maik
> For Translation:
Re: [xl7] Re: SPDIF signal enhancers
audio takes a hit, so to a degree one has to weigh which hit they prefer -
N or A/D.
>>>Hmmm, not sure I agree actually (though not sayig you're wrong either).
 Normalization is a fairly simple operation, you're just adding more bits
to the existing signal, not altering it or performing any calculation that
could introduce truncation errors. <<<
I find myself continually more drawn to an analog re-recording of the XL7
>>>Me neither, the analog outs are certain fine, and I too use those most
of the time. <<<
>>>This is where you'll start to incure errors though.  Any time you raise
the gain of a digital signal via software (ala, you raise the input fader
in your DAW) you're performing calculations on the signal.  Truncation
errors can occur, so the signal will not be as clean as it you had just
recorded it straight and then normalized after the fact.  That being said,
lets keep this all in perspective.  Truncation errors occur at roughly
round -144dBFS in a 24 bit signal, so it's hardly likely you'd be able to
hear them.  If nothing else, the dither added during bit reduction later
in the process will be louder than those errors.  The issue with
truncation errors is that it's cumulative, so the more operations you do,
the more likely you are to hear them.  Again, these are VERY small in
terms of how they degrade the signal quality though. <<<
recording of individual tracks is -6 db (Bob Katz, the Metric Halo guys et
>>>For recording individual tracks, yes I agree, you're only losing 1 bit
of resolution in a 24 bit signal, so it's no big deal (for those that
don't know each bit in a 24 bit signal is about 6dB of level).  My
comments were geared ONLY towards normalization, and I used the -2dB as an
"upper" limit.  To be honest, if I record the XL-7 digitally, I just leave
it at around the -14dB it's typically was recorded at, and don't even
bother to normalize.
When I track individual instruments, I too aim for around the -6dB mark.
Anyone interested in this geeky kind of stuff should definitely get the
book "Mastering Audio" by Bob Katz, goes into much more detail on all of
these topics, very highly recommended. <<<
roll backward,
For Translation:
Good Points rEalm
FWIIW (in my limited experience based on the hardware/software that I
own and work on) - I think some software will perform XXX operations
better than other soft/hard. I have experienced over the years what I
have subjectively considered to be "bad Normalization" and "good
Normalization)....
I am currently working with a Creamware SFP system and the Digital
Gain that is available in the SFP mixer is great (imo) - but I guess
what you are saying is that a more sure-fire QC method is
Normalization, not Digital gain...and I can see the logic there.
Which raises the question: In the E4 we do not have to think about
this exact subject in the same way given the variable HEADROOM setting
in the MASTER section (allows digital signal to be raised or lowered)
- do you know who this type of operation figures into all that we have
been discussing here?
curious to know your thoughts
thanks!
Ed
prefer -
> N or A/D.
either).
bits
calculation that
the XL7
most
> of the time. <<<
raise
fader
said,
able to
later
you do,
guys et
1 bit
as an
leave
mark.
all of
> roll backward,
> rEalm
> For Translation:
I think some software will perform XXX operations better than other
soft/hard. I have experienced over the years what I have subjectively
considered to be "bad Normalization" and "good Normalization).
>>>Not disagreeing here, I just don't have enough experience with other
software to verify.  I personally use Wavelab 4 for all of my audio
editing, and always have.  In "theory", normalization shouldn't involve
any calculations that would affect audio quality (you're just tacking on
extra bits), though certainly each manufacturer can have a different way
of doing it. <<<
I am currently working with a Creamware SFP system and the Digital Gain
that is available in the SFP mixer is great (imo) - but I guess what you
are saying is that a more sure-fire QC method is Normalization, not
>>>Pretty much hits it on the head.  I think there are vast differences in
how various software companies calculate things like gain change, so
certainly some manufacturers are better than others in this regard.  It's
all about the processing resultion (is the signal path 24 bit, 32 float,
64bit, etc), and more importantly, how do they deal with any calculation
remainders.  Some companies used to just 'throw away' the extra bits
post-calc, ouch! <<<
Which raises the question: In the E4 we do not have to think about this
exact subject in the same way given the variable HEADROOM setting in the
MASTER section (allows digital signal to be raised or lowered) - do you
know how this type of operation figures into all that we have been
discussing here?
>>>Without knowing how it's implemented, I can't say. I'm totally
unfamiliar with the Emu sampler range too.  Again, 'in theory' anytime you
change the gain digitally, you're affecting the quality of the audio.  But
as I said in the last email, we're talking about VERY minor amounts of
distortion.  Much lower than the noise floor of tape for instance. <<<
For Translation:
2004-02-11 by Aaron Eppolito
--- erik_magrini@... wrote:
> In "theory", normalization shouldn't involve any calculations
> that would affect audio quality (you're just tacking on extra bits)
Not quite.  Normalization involves a multiply by a non-integral number
which leads to error, albeit down below the level of the original bit
depth.  For example, pretend you have a 2 bit system (4 levels).  If
you normalize a signal of 1,2,1,2 you'd have to multiply by 1.5,
leaving you with 1.5,3,1.5,3 which truncates to 1,3,1,3 or rounds to
2,3,2,3.  Either are wrong to the tune of up to a single bit.  While a
single bit is significant in a 2 bit system, it is negligible in a 16
or 20 or 24 bit system.
Wow, that was technical...
And my standard disclaimer, the only reason to record the analog
instead of digital is because you like the color of the XL-7's D/As,
preamps, or A/Ds you capture with.  The digital will *always* be
cleaner.
-Aaron
Do you Yahoo!?
Yahoo! Finance: Get your refund fast by filing online.
http://taxes.yahoo.com/filing.html
2004-02-12 by erik_magrini@Baxter.com
Yes very technical, not a clue what you just said :)  Thanks for that
though Aaron, I never realized normalization involved a multiplication
process, points to Ed.
For Translation:
