--- In xl7@y..., "musicaemagister" <musicaemagister@y...> wrote:
> Can anyone give me an example of how to assign a knob to an
effects send amout if you are using the fx in a preset to control
the master FX settings. You can set this up on the
FX MULTIMODE CONTROL window in the global menue, select use preset
select the preset channel and then set up the controllers to
controll the fx send. This part is spelled out in the manual.
> parameter or is this impossible?
well you can use a conroller to change the FX send
> Why are their 95 control numbers and only like 10 of them do
> anything???
You can use more of them than ten, it allows for more flexability
when using external gear as well.
You might want to come to the Yahoo group called IBGEEK there is a
link in the bookmarks section of this group. look for
<----cord talk----> I would love to see you there.
Hope that helps
Mike
> Please help.
