Idea for dynamic 1 measure fills in patterns
2004-02-03 by critten98
I can't recall the post, but someone recently asked about hwo they could do 1 measure fills. I will try this idea when I have some free time this week, but wanted to run it by you. Couldn't you design a drum preset so that it had 4 layers of the same kit, each RTXFaded and transposed across a 4 octave range (or 8 if youwanted, 2 octaves per layer). Then record track 1 to have a 4, 8, 16 or 32 bar pattern of your liking in Octave # 1 (preset 1). Also record constant 1 measure "fills" of your liking in octaves 2,3,4 for all measures. Route touchstrip to realtime crossfade, and then have dynamic/spontaneous fun. You should also be able to expand on this idea using different kits, preset links, effect routing, etc... Comments?
