Re: [xl7] Again: Can you explain it?
2002-01-10 by erik_magrini@Baxter.com
If you set the PC for channel 1 to off, then maybe its not loading a Preset on that channel when the pattern first loads, and therefore you're not getting any sound. Changing Presets works, because now you've got a PC command happening telling the EMu to load a sound. Try turning the PC enable back to ON for that channel and see if it still happens.
Also, is it only that one Preset that this happens with?
This is what happens:
I recorded a midi drumfile (I tried both: emgaic and cake walk, mp-7
tempo setting in the mp-7 set to ext., the enable program change in
channel 1 set to off) on track 1 of the mp-7. When I want to run the
sequence, theres no sound. But the green light indicates midi events
playing. When I change the preset of track 1 (another kit) I can hear
the sequence. Switching back to the original kit works. I can still
hear the sequence. When I press the stop button (no matter if once or
twice (to go back to the very start of the sequence)) and replay the
sequemce the sound has gone. To be precise: I turn up the volume knob
to the max, then I can hear the sequence, but very very low,
hardly "detectable" (can you say so?).
Strange enough: I changed to other patterns I recorded and it
happened the same. Befor these patterns didnt cause me any trouble. I
somehow imported the bug just by running the sequence on pattern x
to pattern y.
So: whenever I press the stop button of the mp-7 the sound is gone
(nearly gone).
I checked the controller data: Several #94, vol. 0, but they didnt do
any harm in other selfrecorded patterns (#94 seems to be the fx
setting, right?). I deleted the events, still the same problem. I
deleted the controller data on my computer, befor recording it again
on the mp-7, same problem).
I haven“t used any multiuser setup until now, so no problem from that
side.
Anybody who can explain it?
If you want to put it on the new bugs list, in short:
preset sound is off after pressing the stop button of the mp-7. It is
affecting other patterns when switched to them.
Best regards
HEinrich
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Tiny Wireless Camera under $80!
Order Now! FREE VCR Commander!
Click Here - Only 1 Day Left!
http://us.click.yahoo.com/WoOlbB/7.PDAA/ySSFAA/pWZylB/TM
