do anyone know how to fix this (humm)
max is 96kHz) because I have to set the clock to external. When using
internal on the Audiophile, the signal gets disturbed (clicks and
plops). The trick of grounding the S/PDIF output didn't fix it. Am I
doing something wrong?
2) Connecting analog (main or sub):
A humming sound is added to the signal. When I close to software
mixer of the Audiophile the humming stops, but still leaves a lot of
noise en crackles. Totally not acceptable.
Are both problems recognized by anyone? Do the seem to be related?
I also checked the XL-7 on a simple home stereo. It also produces
noise, but it's only noticeable on high volume.
Maik
--- In xl7@yahoogroups.com, "Alan Wrightson" <sapalan@h...> wrote:
> I am having the same SPDIF problems as described in this thread
with
> my PX-7. I have it going into an alesis masterlink via a tc
finalizer
> express, alesis deq320d and m audio c03. Whichever combination of
re-
> routing, and whichever settings on the px-7 I use (aes / spdif) the
> masterlink loses sync with the px-7 every 20 seconds or so. Most of
> the gear has status lights and I have narrowed it down to the px-7
> only (or the one cable) but I only just unpackaged the cable today
> from new, and it is a proel top of the line spdif.
> What proves it to me is that the exact same setup has worked
without
> a single glitch for 6 months when mastering from a d8b and mx2424.
> No, it's definitely the emu hardware.
> So how do I go about earthing the cable? Just a couple of crocodile
> clips and some solder!??
> Alan
> --- In xl7@yahoogroups.com, "glennjamison" <glennjamison@h...>
wrote:
> > I have had problems with the s/pdif output on two separate MP-
7s.
> I
> > haven't been able to get either to work and I also have no
problems
> > with any of my other s/pdif gear. I've tried plugging the MP-7
into
> > various s/pdif ports with various cables, and since I've had the
> > problem with 2 separate MP-7's, I'm assuming it's not a problem
> with
> > the unit. I have set it to s/pdif and not aes/ebu in the
settings
> in
> > the MP-7. What I do get when I hook it up is a whole lot of
> digital
> > noise. I've tried synching word clock to the s/pdif port on the
MP-
> 7
> > and I've also tried using a sample rate converter so that I don't
> > have to sync to the MP-7's s/pdif port, but nothing seems to
work.
> > If anyone has any ideas, please let me know.
> > Glenn
> > --- In xl7@yahoogroups.com, "clintfisher" <clint@f...> wrote:
> > > --- In xl7@yahoogroups.com, aeon <aeonlux@c...> wrote:
> > > --snip---
> > > > I am not experiencing it, nor are others on this list, so I'm
> > > thinking
> > > > something is wrong with your cable, clock sync or method.
> > > Actually, others on this list *are* experiencing this, which is
> why
> > I
> > > decided to chime in. I'm connecting the XL-7 to an Aardvark
Q10
> > and
> > > have tried all clock sync methods available in the driver.
> > > It's important to note that no other SPDIF gear I have has a
> > problem
> > > connecting through my Hosa "digital" (SPDIF) cable to the Q10.
> > Units
> > > tried: Apogee Mini-Me, CO2 (optical-spdif converter), C03
> (higher-
> > > quality optical-spdif converter). All perform flawlessly.
> > > Oh yes, I have tried different (and shorter) cables with the
same
> > > results.
> > > Others here have indicated a weak signal coming from the XL-7.
> > > Granted, I have not done anything *myself* to measure the
actual
> > > SPDIF signal strength coming from the XL-7 versus my other
> devices,
> > > but this does concur with the behavior I am experiencing.
> > > My next test will be to use a *very* short cable out to the CO-
2
> > and
> > > hopefully use it as an amplifer in between my Q10 and the XL-7.
> > > The bottom line is that other equipment works fine while the XL-
7
> > > suffers. I believe it to be a defective design or output
> circut.
> > > Others on this list have corroborated this.
> > > The biggest reason for me wanting to use the SPDIF out, aside
> from
> > > the panacea of "perfect digital quality" is that the Q10 has
ten
> > > input channels, 8 analog, and 2 digital via SPDIF. This
> > effectively
> > > frees up two analog channels for me, which is invaluable.
> > > Any information anyone can offer on a way to *resolve* this
issue
> > > would be most appreciated. I'll try hardwiring the cable
ground
> > too.
> > > -Clint
Yahoo! Groups SponsorADVERTISEMENT
Yahoo! Groups Links
To visit your group on the web, go to:
Do you Yahoo!?
New Yahoo! Photos - easier uploading and sharing
