From page 17 of the G-revision of the XL7 Manual:
"Audio Outputs
Three sets of programmable stereo outputs (Main, Sub 1, and Sub 2)
are provided. The internal effects are available only on the Main
outputs.
Specific presets (or MIDI channels) can be routed to one of these
stereo pairs in order to be processed further or mixed separately.
The S/PDIF output duplicates the function of the main outputs."
- I route my kicks, on ch1 one, this way to a specific output,so if
you are consistent in how you map your presets, it should work.
If you don't have this latest copy of the manual, download it from
the files section, its much updated from all the printed manuals I
have seen.
And like it has been said, don't get too frustrated, as I know from
not being able to figure out what I wanted to do for months, and
rather than give up (which is where I was going) a tip from someone
here made me go back and try again and I finally got it working..
Dana
--- In xl7@yahoogroups.com, "bezowinz" <bezowinz@y...> wrote:
> First, thank you for taking time to explain some of this stuff.
Let
> me see if I got this.
> I'm still a bit confused by your explaination.
> "notice that the preset can be made up of 4 instruments (layers)."
> This leads me to believe that a preset is the sound on ONE pad,
made
> up of the 4 layers of instruments. But the specs say there are
512
> presets. From scrolling through, I can see that there are 512
kits,
> so I guess that answers my question.
> I am like you in that I put my drum sounds on separate tracks. So
> the kick is on 1, snare on 2, ect.
> In your earlier respons, you said that I can assign a preset to
> specific out. Now I take that to mean the entire kit will be
> assigned to that output. Is that why you suggest that I use a
> kit/preset full of kicks, then a kit/preset full of snares, ect?
Do
> you find it difficult to sequence drums like this?
> Is it possible to instead assign tracks to separate outputs and
pan
> the tracks hard left and right so that I can use the outputs as 6
> individual mono instead of 3 stereo pairs? This would allow me to
> sequence using a kit containing kick, snare, hi hat, ect. and not
> have to continuously switch presets while sequencing.
> Trying to explain things and ask questions online is tough.
> --- In xl7@yahoogroups.com, "phest2k" <tuttle@l...> wrote:
> > I guess the best way to understand what a preset is is to simply
> press
> > the preset button in the *mode/view* area and choose one.Then,
> press
> > the other preset button in the *edit* area(top left-hand side of
> yout
> > xx7).In the preset edit scroll down one page and you will see
> > *instrument* screen.Move the cursur to L1 and scroll around and
> you´ll
> > Now, for drum sounds, these instruments can be either a whole
kit
> > spread out over the keyboard range or a single drum spread out
over
> > the keyboard range.
> > If ,as I do, you only ever need a kick drum on track 1 then
> (depending
> > on which ROM you have) you can create a preset with only kicks
> spread
> > all along the keyboard range (i.e a kick will sound a C# when C#
is
> > played on the keyboard - alternativly you can choose a whole
bunch
> of
> > kicks that sound completely different -like a palette of kicks).
> > Elswhere in the preset edit function you can change all sorts of
> > things like filters,patchcords etc (see the names underneath the
> > trigger buttons - the LEDs light up as you scroll.
> > The manual also speeks of instant gratification - they don´t
> mention
> > that this is soon followed by instant frustration!It takes a lot
of
> > practice and hanging around in this group, trawling the
archives -
> but
> > I´m sure you´ll get there soon.
> > Don´t let it grind you down - its a great machine.
> > :paul
