Can someone please help?
2004-01-18 by mike
I need parts for my xl7
My track one mute button is on it's way to the grave.  I can use the
mutes on my mixer but it it is just not the same.
Anyone ?  h e  l   p      m    e     p   l  e  a se!
Mike G.
Re: Can someone please help?
2004-01-18 by xkrider1
Mike,  This may not help, but when I got my new PX7 recently, it had
a mute button that would work when pressed at the top edge but
wouldn't work when pressed toward the bottom edge. I was intending to
return it for another one, but,in desperation/frustration, decided to
try hosing it out with a portable air compressor (w/ nozzle
attachment) and, unbelievably, it started working just fine. This
button felt like it should work, i.e., the same action as the others,
but just wasn't making complete contact, apparently.  If your's feels
different than the others, it probably is something more mechanically
wrong.  Still, if you have access to a low power air compressor (we
used to use this one for a yearly cleaning in a computer lab), you
might give it a try.  I've never opened my Emu, so I don't know if
you could get any better access to the keys from inside or not. (I
just shot the air right down through the front panel, while working
the button.) Probably a long shot, but ya never know; certainly a
pleasant surprise to me.  Whatever, Good Luck,  Ken
> Mike G.
2004-01-18 by mike
Thanks for the advice i think i just might give that a try!
Mike G.
had
to
to
others,
feels
mechanically
> the
> > Mike G.
