Re: Can you explain it?
2002-01-08 by boomtap
1. Since then I noticed that the kickdrum on track 1 (kit preset) in
another user pattern that I programmed earlier changed to a hihat
sound. I never changed a thing on this pattern! Weird.
Select the Midi Button and turn the dail to SELECT PROGRAM CHANGE and
turn certain channels that are on to off. I had this problem also
when I had a certain sound selected and when I restart the pattern
everything would change. It piss me off for awhile so I started
playing with the settings. I had to go check again but I think how
you resolved that problem.
2. The drum pattern I recorded started very low and heavily equalised
with no trebles at all. When I change the preset drum kit (factory)
the volume has gone up and the eq sounds as it is supposed to do. I
switch back to the original drum set and everything seems okay. When
I restart the pattern from the first bar I have the same problem
again. I assume there is a controller event messing the mix up? How
can I get rid of it? I failed using the new edit pattern feature in
OS 1.18.
Try this to see if it works... Select the EDIT button and turn the
knob to Erase events and select CC# 7 VOLUME and erase the volume
events from those tracks that are changing. Doing this has solve alot
of volume issues for me.
I hope this helps
Boomtap
