Re: [xl7] trying to make the XL control my external gear
2004-01-15 by erik_magrini@Baxter.com
The external devices will stop and start from the controls on the XL7, but
they only play the internal patterns (with their limited sequencing
abilities) not the midi information the XL should be feeding them with.
>>>So when you press play on the XL-7, the ER-1 etc will start their own
internal sequencers, but they won't use the midi note data that the XL-7
is sending, right?  What about if you set the ER-1 etc to not use ext
sync?  Will that work? With the Korg series, that's the only way I can
think of to get them to not start their own sequencers...<<<
One last thing to note, whenever I save the pattern, it messes with the
preset that is called up on the EA1 and ER1 (not the DX200). I know that
the pattern will hold that information, but I don't know how much room I
need to leave at the beginning of any track so I can input this
information ? is one tick enough? Won't this mess up the
timing of the sequence?
>>>Well, without testing it, this is all speculation, but I think it WOULD
affect the timing of your sequence, but only for brief moment the very
first time that pattern plays.  It won't happen everytime the pattern
loops, as long as you put the sysex on the first tick, or tick 0.  I think
that 1 tick will be fine too (in terms of length).<<<
(I'll try playing with this some more tonight).
material from any computer.
For Translation:
Re: trying to make the XL control my external gear
2004-01-15 by dwoodaman
XL7, but  they only play the internal patterns (with their limited
sequencing abilities) not the midi information the XL should be
feeding them with.
their own internal sequencers, but they won't use the midi note data
that the XL-7 is sending, right?
-------exactly, they only play their own internal sequence patterns.
> What about if you set the ER-1 etc to not use ext sync?  Will that
work? With the Korg series, that's the only way I can think of to
--------not use ext sync? I could try that, but I would guess that
it might make their timing get weird, worth a try tho...
with the preset that is called up on the EA1 and ER1 (not the
DX200). I know that the pattern will hold that information, but I
don't know how much room I need to leave at the beginning of any
track so I can input this information ? is one tick enough? Won't
this mess up the timing of the sequence?
it WOULD affect the timing of your sequence, but only for brief
moment the very first time that pattern plays.  It won't happen
everytime the pattern loops, as long as you put the sysex on the
first tick, or tick 0.  I think that 1 tick will be fine too (in
terms of length).<<<>
--------more food for thought. thanks a bunch rEalm, maybe I WILL be
able to make this work!
Dana
Re: [xl7] Re: trying to make the XL control my external gear
>>>Perhaps because they are all using a different MIDI channel, the Korg's
thru's aren't passing on other channels data? Just a guess.  BTW, you see
the new Electribes that replace the ER-1 and EA-1  :)  <<<
not use ext sync? I could try that, but I would guess that it might make
>>>The only thign I can see it affecting is teh delay times if you use
that affect. Every other parameter is independant of tempo sync (at least
on the ER-1). <<<
Yahoo! Groups Links
To visit your group on the web, go to:
Your use of Yahoo! Groups is subject to:
use of, or taking of any action in reliance upon, this information by
For Translation:
2004-01-15 by sounddaddy@comcast.net
Try IGNORE ext song start on your ext. boxes
  Sent: Thursday, January 15, 2004 2:37 PM
  Subject: [xl7] Re: trying to make the XL control my external gear
  feeding them with.
  Dana
        Yahoo! Groups Sponsor
              ADVERTISEMENT
  Yahoo! Groups Links
    a.. To visit your group on the web, go to:
    b.. To unsubscribe from this group, send an email to:
    c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2004-01-16 by dwoodaman
the Korg's thru's aren't passing on other channels data? Just a
guess.  BTW, you see the new Electribes that replace the ER-1 and EA-
1  :)  <<<
--------I could try setting them all to the same channel, but that
just seems sorta I don't know, backward to me. Worth a shot I spose,
I just wish the xl worked as easy as sonar does.......
I almost held out for one of the new tribes, but I thought the xl
would be better for ---- controlling external devices........
use that affect. Every other parameter is independant of tempo sync
(at least on the ER-1). <<<
----------good to know that, although I do use the delay timing a
lot naturally
d
2004-01-16 by erik_magrini@Baxter.com
Nah man, BRAND NEW E-tribes announced yesterday, not the ESX-1 or EMX-1.
lot naturally
d
Yahoo! Groups Links
For Translation:
Whoops, I see those now. Too bad they didn't really make them that
much better, esp the EA1 with its total crap ADSR.....oh well guess
I am happy sticking with what I have. I DO think its cool that Korg
seems to contiune to develop their lines, and not just make one-ff
things that could be cool if they just developed.....
EMX-1.
> rEalm
you
sync
> lot naturally
> d
entity
legally
than
privilege
other
by
> For Translation:
