Recording arpeggiator
2004-01-14 by gutman75
Is it possible to record whatever arpeggiator is currently playing to
a pattern? Sometimes arpeggiated drums make cool loops, which are
hard to recreate; how can I capture them in the sequencer?
have a nice day!
Boris.
RE: [xl7] Recording arpeggiator
2004-01-14 by Jody Douglas
This is found in the files section under Tips & Tricks:
Connect a midi cable from the midi out to the midi on of the xl-7, and
make sure MIDI Thru is off. You may need to manually erase the 'trigger'
note, as well as shift the start times of the arp notes too if they are
delayed slightly.
Sent: Wednesday, January 14, 2004 3:21 AM
Subject: [xl7] Recording arpeggiator
have a nice day!
Boris.
Yahoo! Groups Links
To visit your group on the web, go to:
Your use of Yahoo! Groups is subject to:
Re: [xl7] Recording arpeggiator
2004-01-14 by erik_magrini@Baxter.com
The easiest way is to just Save the Preset with the arp on, and just use a
single note trigger in the sequencer.  To record the actual notes to a
Pattern/Song is a bit convoluted.  I helped someone onthis list with this
a few months ago, can't remember how we got it to work though.  Anyone?
gutman75 <bgutman@...>
01/14/2004 02:21 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
have a nice day!
Boris.
Yahoo! Groups Links
use of, or taking of any action in reliance upon, this information by
material from any computer.
For Translation:
It's not quite as simple as that after all, I need to remove it from the
Tips and tricks.  The problem, is that you still get a midi feedback loop
while recording.  If you have soft sequencer, it would be far easier to
just recor the arp ni that, then use E-loader to transfer it to the XX-7.
If you don't have a soft sequecner, you need to set the Record channel to
MultiB is I remember correctly (with NO Preset selected on the destination
track).  Once it's recorded, you can set that track back to whatver
channel you want.  I think this is the way I figured this out.
"Jody Douglas" <jdouglas@...>
01/14/2004 07:07 AM
        cc:
        Subject:        RE: [xl7] Recording arpeggiator
delayed slightly.
have a nice day!
Boris.
Yahoo! Groups Links
Yahoo! Groups Links
For Translation:
2004-01-14 by lynn
just go ahead and record it as audio
To: <xl7@yahoogroups.com>
Sent: Wednesday, January 14, 2004 7:07 AM
> delayed slightly.
> -----Original Message-----
> From: gutman75 [mailto:bgutman@...]
> have a nice day!
> Boris.
