Can you explain it?
2002-01-08 by heinrich22001
Hi, I recorded midifiles (drumpatterns) from cakewalk sonar to the mp7 and saved the patterns. 1. Since then I noticed that the kickdrum on track 1 (kit preset) in another user pattern that I programmed earlier changed to a hihat sound. I never changed a thing on this pattern! Weird. 2. The drum pattern I recorded started very low and heavily equalised with no trebles at all. When I change the preset drum kit (factory) the volume has gone up and the eq sounds as it is supposed to do. I switch back to the original drum set and everything seems okay. When I restart the pattern from the first bar I have the same problem again. I assume there is a controller event messing the mix up? How can I get rid of it? I failed using the new edit pattern feature in OS 1.18. 3. I saved my recorded patterns but the presets on the tracks still change every time I restart the mp7. Why is that? When I change patterns the presets do not change despite the different settings I saved? Uuumh? Anybody who knows whats going on here? Heinrich
