Thanks for the answers, I have explained questions 1 and 3 in more
detail below.
The difference between my Question 1 and 3 is that I am referring to
the modes that the XL-7 has. As far as I am aware you can set the
buttons to use "Track Enable/Mute" or "Triggers".
Q1. I want to be able to send a sequence (loop) out the MIDI Outs to
my synth and/or sampler instead of to the XL-7 internal sounds. For
example button 1-4 enable/mute the loops for the XL-7 internal drum
set. Then button 5-8 are configured to enable/mute loops that are
sent to my Virus b via the XL-7 MIDI Out A, then buttons 9-12 to my
sampler via MIDI Out B.
Q3. When the buttons are in "Triggers" mode I know it is possible to
send one note to an external device such as my sampler, but is it
possible to send a sequence of notes (a loop) that I have programmed
(i.e. not just an arppegiator of one note)
Glenn
glennvassallo@...
--- In xl7@y..., "www.mp3.com/koering" <A.Libi@b...> wrote:
> > 1) Is it possible to use some of the Track Enable/Mute buttons to
> > send a looped sequence of midi notes out the XL-7 MIDI Out A
and/or B
> > to the synth or sampler?
> hmmm why not? think yes.... I use also a Virus b in my livesets and
you can
> send arps to midi a or b.... which are played from da virus... all
over all
> I programm patterns which are looped... isn´t it the same?
> > 2) Is it possible to use the Keypads to trigger the synth or
sampler
> > like you would with a MIDI keyboard. (Mainly to play Samples on
> > fly)
> I use an EMU esi-32 and it works..... you´ve only one octave....
but also
> the transpose buttons....
> > 3) Is it it possible to use the trigger functionality to trigger a
> > sequence of notes (instead of one note) to send out the XL-7 MIDI
Out
> > A and B.
> think is that what emu calls ARP´s..... pretty nice feature.... but
thats
> question one?????
> > 4) Is it possible to change a Track for a Pattern in real-time
> > without having to stop the performance. i.e. Change a loop for a
> > track while continuing to play live. Or at the very least change
> > entire Pattern so that long live sessions are possible
> well.... while one pattern is playin you can search for da next
one... the
> old one playes to da end and than it switch to the new one....
> all over all the xl-7 is the best live machine I have ever
played... ( also
> own before the Yamaha RM1x and the Rolan MC-80)... maybe the rs7000
is also
> good, but I don´t like yamha with thousands of little
menues.... .... and
> also you say u use an akai sampler... so why the rs7000? also good
are the
> 16 programmable knobs... real great while youre live actin....
> greeetz
> dietmar
> From: "glennvassallo" <glennvassallo@h...>
> To: <xl7@y...>
> Sent: Monday, January 07, 2002 7:58 AM
> Subject: [xl7] Live Performance Features?
> > I have a Virus B synthesiser and an Akai S2000 Sampler. I want to
be
> > able to do the following by using the XL-7, and was wondering
what is
> > possible. My questions are coming from a live performance
> > perspective, where I use an XL-7 as the master controller to
sequence
> > my synth and sampler.
> > Questions:
and/or B
sampler
> > fly)
Out
> > A and B.
> > entire Pattern so that long live sessions are possible.
> > Glenn
> > glennvassallo@h...
> > To unsubscribe from this group, send an email to:
> > xl7-unsubscribe@y...
> > Your use of Yahoo! Groups is subject to
