Is anyone recording into wavelab?
2004-01-09 by dj 61
What pc software would you suggest for recording. I lost logic on a
crash and am using wavelab, but it seems to come out at a rather low
volume although in the wave view it appears to have very little room
left. Are the top and bottom edges of the graph not the clipping
points. Can I set a hard limit for recording or is it only for post
recording processing? I know these questions are kind of newbie and
not e-mu, but you guys/gals seem to be able to explain anything:)
Here I'll add some e-mu stuff to stay in topic... Also my e-mu
requires much more volume through the mixer than other channels. I
have to turn the gain all the way up on it and about half way down
on my tables to even them put. Is there a simple solution like a
master amp level in the mp-7. I know the layer amps, but this is not
a good solution.
 To avoid a string of thank you posts from me, please refer to the
next line after posting your reply.
 Thank you for your reply your help is greatly appreciated.
     Tom
Re: Is anyone recording into wavelab?
2004-01-09 by phest2k
--- In xl7@yahoogroups.com, "dj 61" <dj61@d...> wrote:
" What pc software would you suggest for recording."
I use wavelab for sample editing. If the volume is levelled of at 0db
it should send out 0db - check your pc soundcard level settings.
"Also my e-mu requires much more volume through the mixer than other
channels."
As rEalm suggested in an earlier mail - its posible to give your
presets more "umph" if you copy the layers on top of oneandother.
(press the save/copy button and scroll down to copy layer x to layer
x.
:P
Re: [xl7] Is anyone recording into wavelab?
2004-01-09 by erik_magrini@Baxter.com
I use Wavelab extensively (almost daily for my "post" work), so maybe I
can help.  Answers below:
I lost logic on a crash and am using wavelab, but it seems to come out at
a rather low volume although in the wave view it appears to have very
little room left. Are the top and bottom edges of the graph not the
clipping points. Can I set a hard limit for recording or is it only for
post recording processing?
>>>The output from the XX-7's can be a bit low, and as always you shoudl
go by what you hear, versus what you see in wavelab.  That being said, I'm
not sure what you mean by the "top and bottom edges of the graph".  Do you
mean the waveform display, or are you referring to the FFT or peak meters?
 As long as you're not clipping, you should be fine.  On question, are you
recording digitally, or via the main analog outs?  What's your soundcard
too? (ok, that's two questions) <<<
channels. I have to turn the gain all the way up on it and about half way
down on my tables to even them put.
>>>Yeah, I find that when I use the XL-7 in my DJ sets, I need to crank
the channel gains up all the way, probably twice as hot as the channels my
tables are going through.  This is normal, after all the records you're
listening to have been compressed many times, and most definitely squashed
during mastering too, so they'll always be hotter than a direct out from
the XX-7.  I find a compressor to be almost essential in helping the XX-7
fit into a DJ set better, other wise when you go from records to the XX-7,
the difference in sound is very noticeable, even at the same volumes. This
is due to the fact that the signal from the XX-7 is much more dynamic than
the records.
The only solution I've found (and what I'd do even if I wasn't using the
XX-7 with myu DJ set up), is to layer up your drums with two percussion
layers, and use the AmpVol in the Preset Edit menu too.  you can get a
pretty hot signal that way.  Let me know if you need more info on this.
use of, or taking of any action in reliance upon, this information by
material from any computer.
For Translation:
2004-01-10 by DJ 61
Thanks Andy,
 I have more!
  As you pointed out things change with the zoom and
it sems quite drastic, a spike may shrink to less than
half the height as I zoom. This does not really make
sense to me. So from what you said the closer zoom is
the more true the amplitude? It seems to continue to
shrink as I zoom As for cool edit I have thought about
working with taht after watching the speed at which it
was able to do processing at my friends... my wavelab
seems substantially slower on a similar pc. I usually
record and then compress gain compress as necessary,
but I decided I prefer the sound of my hardware
compressor. On my last set of recordings I set the
mixer output to were the peaks would hit near zero. I
then set the compressor ~2:1. I can't recall the
decibal setting at the moment, but I can check next
time I am near my compressor; I don't think it has
been adjusted again. It was probably between 15 & 20.
Smoothing the peaks, but not completely squashing the
sound (maybe I should hop on the bandwagon) I then
adjusted the output gain to where the signal peaks
were near the same level on the mixer. Next I recorded
into wavelab. Afterwards, I adjusted the gain until
the peaks appeared near zero. And everythinfg sounds
fine on my monitors. I burned to cd put in an internet
connected computer and uploaded to soundclick. Sounded
fine, until I compared with others on the charts and
most of them sound 2-3 times louder as in I have to
adjust the volume to ~30%.
 I am going to cc this back to the board as well.
--- electrolama <andylama@...> wrote:
> Hi Tom,
> I'm not using Wavelab, but I'll take a shot at your
> question:
> Disclaimer:  I'm not a professional recording or
> mastering engineer--
> just a hobbyist who has learned a thing ot three...
> I use Sonar 3 for recording and CoolEdit2000
> (shareware) for editing
> and mastering.
> The top and bottom edges of a graph ARE the clipping
> points, BUT
> there's a few things to understand about this:
> Graphs are 'roughly representational' and the peaks
> that appear to
> touch the 0dB point may not in actuality.  Case in
> point: zoom all
> the way in to the sample level and see how high it
> really goes.
> Remember that when looking at a waveform on a graph,
> that any given
> peak may represent dozens or hundreds of samples at
> all different
> levels.  These are all glommed together and
> displayed by a single-
> pixel-wide spike.  Can be visually misleading at
> first.
> "Setting a hard limit during recording" is the job
> of a
> compressor/limiter.  Although I own a limiter, I
> avoid using it this
> way because it can make changes to the incoming
> music that cannot be
> undone.  The solution is to record a little quieter,
> then boost the
> recorded signal.  Read on:
> Let's say you have a waveform that isn't very "wide"
> onscreen.  Do
> not automatically interpret this as being "quiet".
> Volume is not
> determined entirely by the overall amplitude or
> "fatness" of the
> visual waveform.  Loudness has more to do with the
> overall dynamics
> (difference between the average low point and
> average high point of
> the waveform).  Some folks may simply recommend that
> you "normalize"
> the waveform, but I think you'll find that this
> doesn't actually make
> the wave louder because it doesn't do anything to
> the dynamics (a bit
> like suggesting that you will be taller if you stand
> at the top of a
> staircase).
> Case in point: take a few commercial CDs and rip a
> few tracks at
> random and look at them in your wave editor.  The
> waveforms aren't
> always huge, are they?  But they are all LOUD,
> aren't they?
> Now, when I'm "mastering" a track, I use a feature
> in CoolEdit
> called "Hard Limiting".  This is actually a limiter,
> but it does
> actually do something to widen the dynamics and make
> the track
> louder.  I set the settings so that the waveform is
> boosted JUST
> SHORT of the point where the peaks start to get
> crushed down.
> The important lesson:  don't overdo it. (compression
> and limiting)
> Read a book about recording and mastering
> engineering (there are
> several out there).  One thing that masterers gripe
> about is the
> current fashion of overcompressing recorded music to
> make it as
> bloody loud as possible.  This actually makes the
> music suffer.
> Have fun--I certainly do.
> Andy
> I lost logic on a
> out at a rather
> low
> have very little
> room
> not the clipping
> it only for post
> kind of newbie and
> explain anything:)
> Also my e-mu
> other channels. I
> about half way down
> solution like a
> amps, but this is
> not
> > a good solution.
> please refer to the
> appreciated.
> >      Tom
2004-01-10 by dj 61
1) Waveform display
2) Analog
3) Delta
Yeah, I got a compressor to try to bring them e-mu-records together.
I have just been using it on the master insert, but maybe this is
not the best approach. Perhaps I should add a heavier compression to
the e-mu sends and then a lighter compression to the master for
final smoothing. I have also been informed that a little work with
the normalization in wavelab should allow me to maximize the
recording without clipping or continous trial and error.
maybe I
out at
very
only for
shoudl
said, I'm
graph".  Do you
meters?
are you
soundcard
other
half way
crank
channels my
you're
squashed
out from
the XX-7
the XX-7,
volumes. This
dynamic than
> the records.
using the
percussion
get a
this.
> rEalm
entity
legally
than
privilege
other
by
> For Translation:
2004-01-10 by dj 61
So I don't have to use links it will double up to just copy the
layers. I assumed the copy would just replace the previos one.
What's that saying? "Assumption is the mother of all F___ ups"
0db
other
> channels."
layer
> x.
> :P
2004-01-10 by S V G
I discovered Cool Edit Pro a few months ago.  Now they are owned by Adobe and have been
renamed Adobe Audition (they are just downt the street from me).  I have a friend here in town who
wrote the manual and he's pretty up on the whole schtick.  Anyway, CoolEdit is an amazing tool.  I
hate software written by nerds for nerds.  CoodEdit was written by engineers for engineers.  If
you know your way around a recording studio, CoolEdit will make maximum sense.  Very few software
programs out there work this intuitively.  As for speed, I've never used Wavelab so I don't know
how to compare the two.
     CoolEdit does not work for everything.  If you want to do multitracking on your computer,
CoolEdit will do it though it's not optimized for it.  It is optimized for mastering, editing,
recording in stereo, and splicing and dicing.  If multitracking is what you're after, check into
Nuendo.
     Stephen
<<<<As for cool edit I have thought about
seems substantially slower on a similar pc.>>>>
Do you Yahoo!?
Yahoo! Hotjobs: Enter the "Signing Bonus" Sweepstakes
http://hotjobs.sweepstakes.yahoo.com/signingbonus
RE: [xl7] Re: Is anyone recording into wavelab?
2004-01-10 by Matt Picone
> Nuendo.
Try Sonar 3 instead. Best of both worlds, and it integrates with
CoolEdit seamlessly.
-m@
Re: [xl7] Re: Is anyone recording into wavelab?
2004-01-12 by erik_magrini@Baxter.com
Nope, you don't have to use the Link Presets function.
0db
other
> channels."
layer
> x.
> :P
Yahoo! Groups Links
To visit your group on the web, go to:
Your use of Yahoo! Groups is subject to:
For Translation:
As you pointed out things change with the zoom and it sems quite drastic,
half the height as I zoom. This does not really make sense to me. So from
the more true the amplitude? It seems to continue to shrink as I zoom
>>>I've seen this a couple of times, but again, you can't judge music with
your eyes or a waveform display.  IF you think there's still a spike
there, and it's not just a weird glitch, use the FFT meter to confirm it.
It was probably between 15 & 20. Smoothing the peaks, but not completely
squashing the sound (maybe I should hop on the bandwagon)
>>>Please don't, over-compressed music is not a good thing, regardless of
how many people are doing it. Drives me nuts hearing music squashed to
shit...<<<
I burned to cd put in an internet connected computer and uploaded to
soundclick. Sounded fine, until I compared with others on the charts and
most of them sound 2-3 times louder as in I have to adjust the volume to
~30%.
>>>Probably a lot of people are using things like Finalizers or other
peak-limiters to get a higher RMS level, which is different from the peak
level. Normalizing only goes off of the peak level.  <<<
I have also been informed that a little work with the normalization in
>>>Normalizing is something that takes place after the fact (recording),
so it's not going to help you with that at all IMVHO. I do a lot of post
work lately, so if you have questions about "Mastering", please let me
know and maybe I can help.<<<
For Translation:
