Keeping midi tight
Keeping midi tight
2003-12-21 by mike
I think that in the xl the midi priority starts from track one and
moves down the line.  At least that is what i rember reading.
Am i to take it the Midi B outs are way down the line then? or as
least come in sequence after the A outs?
Trying to keep midi timing as tight as possable is all.
Please give a shout if ya know the answer to this one.  And just a
general question, how do you all find the timing on this box?  I feel
that at times it gets kinda sloppy when i have arps going and what
not.
Mike G.
Re: [xl7] Keeping midi tight
2003-12-21 by khjkkkkk khjkhjk
To me it feels just fine, way tighter then rm1x that I use to have.All the sequencers have timing issues when a lot of stuff is going on, thats why there is swing.I only use esi2000 as sound module and its not a problem when you nudge the notes with swing and that feature is mainly used for opening up the space.Theoreticaly, two midi outs are as double as better then one becouse one out can only send one note at the time.Sometimes people blame sloppiness on timing of the sequencer, but its 98% of time doe to the composition.Also if you use a lot of control change and pich shift in the recording, that will effect it in a way becouse those kinds od messages contain more data then note on and off.
not.
Mike G.
Yahoo! Groups Links
   To visit your group on the web, go to:
Do you Yahoo!?
New Yahoo! Photos - easier uploading and sharing
2003-12-21 by Wesley D
I think the two outputs def. gives you an edge, it certainly would seem that it doubles the total bytes that can flow out at once.  After that, a MIDI interface does wonders, as opposed to daisy chaining or other weird setups....
Worst case scenario you can take apart a MIDI cable and I believe it's pins 4 and 5 that are 0 & 1 (on and off) and you can solder 'two' jumpers to each one, thereby doubling the output capacity of that cable.
Also, if you're doing filter sweeps and tons of realtime CC messages, perhaps try using a sampler for those riffs.  You can always look at your event list, compare it to the time in seconds and mathmatically figure out if you're trying to put too much MIDI down the MIDI hole, but that's a pain in the arse.  if you're getting flamming and things of that nature, you most likely need to bounce some stuff to audio, or have fewer events.
I used to be in a Live PA and we struggled with this all the time, esp. the syncing of audio loops together with MIDI, this is a wonderful topic, because as tight as you can get, most people I've seen still have a little flam going on, mostly when using several sequencers together.
Peace,
Wesley
Do you Yahoo!?
Re: Keeping midi tight
2003-12-21 by mike
thanks for the feedback.  I was kinda wondering if it is in my head
or not.  So in theory the a outs and the B outs should be able so
send twice as much info at the same time.  Interesting.  I was kinda
hoping that was the case.
take it easy
Mike G.
--- In xl7@yahoogroups.com, khjkkkkk khjkhjk <extra_mayo79@y...>
feel
> not.
> Mike G.
Service.
> Do you Yahoo!?
RE: [xl7] Keeping midi tight
2003-12-21 by Stu
|that cable.
Have you ever actually done this?
multisetup question
2003-12-21 by G e r ä u s c h d i c h t e
i find myself having difficulties to get my head
around multisetups, particularly as to whether
choosing a different multisetup overrides the pattern
settings it.
also: if you reselect the pattern, does it jump back
to 'normal settings' (i.e. the settings you saved your
pattern with) when you reselect it? if so, which
changes are retained from the multisetup?
is it possible to use the programmable knobs to
control external gear in that you can switch between
different multisetups, each of which is controlling 16
control numbers in 1 particular synth? i mean: first
of all, for each multisetup, you assign the 16 knobs
to control functions in one particular synth, or even
2 or more multisetups for 1 synth with a lot of
parametres you want to change. you give the multisetup
the name of the synth its programmable knobs control.
then, while playing/sequencing, you switch between
multisetups depending on the synth you want to control
with the knobs. if i get it right, there's too many
settings changing then, unless you set volume, pan etc
to the same amounts in every multisetup... both with
the pattern as with the multisetup settings are saved
that control the FX, the volume, the pan, the mix
outputs and the arp.
are the pattern settings 'stronger' and overrule the
multisetup? meaning: if i change patterns, do they
sound different because another multisetup is
selected?
thanks for your enlightenments
hans
http://www.electrobel.be/muzik.php?action=list&type=id&data=245
                             http://www.spectre.be
                          http://www.etherialdawn.be
                        http://www.isabellableeds.com
                     -|[ G E R \ufffd U S C H D I C H T E ]|-
__________________________________________________________________
Gesendet von Yahoo! Mail - http://mail.yahoo.de
Logos und Klingelt\ufffdne f\ufffdrs Handy bei http://sms.yahoo.de
2003-12-21 by mike
Yes I am also curious about that one.  That would be kinda cool and
like hell why not?  My other question is what exactly do you meen by
jumper?
Mike G.
> |that cable.
Re: [xl7] multisetup question
2003-12-22 by erik_magrini@Baxter.com
i find myself having difficulties to get my head around multisetups,
particularly as to whether choosing a different multisetup overrides the
pattern settings it.
>>>Recalling a Multisetup will always overwrite all settings in the XX-7.
Pattern data, MIDI, Controller, and Global Settings. <<<
also: if you reselect the pattern, does it jump back to 'normal settings'
pattern with) when you reselect it? if so, which changes are retained from
the multisetup?
>>>Yes and yes.  If I restore a Multi and want to get my current Pattern
settings back, I just do a Revert To Saved.  You can also move to a new
Pattern, and then back to the one you were working on to do this. <<<
Is it possible to use the programmable knobs to control external gear in
that you can switch between different multisetups, each of which is
controlling 16 control numbers in 1 particular synth?
>>>Yes, you'll find a bunch of these I've made already (mostly Reason
stuff) in the Files section of this group. <<<
i mean: first of all, for each multisetup, you assign the 16 knobs to
control functions in one particular synth, or even 2 or more multisetups
for 1 synth with a lot of parametres you want to change. you give the
multisetup
>>>Yes, sounds good so far... <<
then, while playing/sequencing, you switch between multisetups depending
with the knobs.
>>>Yes, sounds good again, provided you aren't using the sequencer in the
XX-7 while you Restore the Multi, as that will stop the sequencer, and
could possible make your pattern sound different too. <<<
if i get it right, there's too many settings changing then, unless you set
volume, pan etc to the same amounts in every multisetup... both with the
pattern as with the multisetup settings are saved that control the FX, the
volume, the pan, the mix outputs and the arp.
>>>Yeah, this is where the flexibility that Multisetups offer, also means
more set up time.  The easiest way to copy all of the Volume, Pan and
effects to multiple Multi's, is to make those settings as you want them,
and then save the current Pattern.  Next, Restore the Multi you want to
apply those settings, and then Revert To Saved the Pattern you had just
saved, then resave the Multi.  This will override the settings stored in
the Multi with those of the Pattern. <<<
are the pattern settings 'stronger' and overrule the multisetup? meaning:
sound different because another multisetup is selected?
>>>Think of it this way, Patterns and Multi's can store the exact same
type of data:
- effects settings (type, amount, sends).
- Preset/track assignments (Patterns do not store the Preset if a track
has no data!).
- soem more I'm sure I'm forgetting
Which of these settings is use for playback depends on only ONE thing,
which was selected/restored last.  If the Multi was the last thing you Restored, then the Multi data gets
used.  If you Revert To Saved, or select another Pattern, then the data
stored with the Pattern will be used. <<<
2003-12-22 by G e r ä u s c h d i c h t e
that clears up quite some things already, thanks!
 --- erik_magrini@... schrieb: > i find myself
> around multisetups,
> the multisetup?
> also move to a new
> on to do this. <<<
> each of which is
> synth?
> or more multisetups
> multisetup
> control.
> with the knobs.
> the sequencer, and
> too. <<<
> the Volume, Pan and
> selected?
> type of data:
> has no data!).
> on only ONE thing,
> gets
> rEalm
> removed]
> Your use of Yahoo! Groups is subject to:
>  http://docs.yahoo.com/info/terms/
2003-12-23 by Wesley D
No but I took an audiotronics course at Full Sail and my teacher told me it was possible.  The application he used it for was a MIDI rig containing five pieces of gear in a chain.  So they put three on one split of the cable, and two on the other, and the latency problem was solved.  I have a MOTU 8X8 interface, which rocks btw, but if you think this quick fix might be helpful, it's not very expensive to try out.  You just need three MIDI cables, a soldering iron, some solder, and some jumpers.  If it doesn't work, you could always solder them back the way they were.
Sorry I can't be more of assistance, but in theory it should work.
Peace,
Wesley
Do you Yahoo!?
Yahoo! Photos - Get your photo on the big screen in Times Square
Re: [xl7] Re: Keeping midi tight
Clarification:  Jumper = just an electronic cable.  basically a rubber casing with some wire inside it.  I say jumper because it's used to 'jump' the flow of electricity from one place to another, most cables have hot and ground, etc., jumper just diverts flow of one path.  you might say a typical MIDI cable has five jumpers running through it (three if it's cheap)
Hoping that makes sense.
-Wesley
Do you Yahoo!?
2003-12-23 by Stu
It will also put your xx-7 out of warranty tho. I can't see the point
either, unless you *really* need to reduce the number of cables in your rig.
Even then a decent midi patchbay (such as the MOTU boxes) is a much more
sensible option. I must add that this mod doesn't increase the amount of
data that can be sent down a midi cable, it just allows 2 midi cables to be
combined into one cable.
Stu
|-----Original Message-----
|Sent: 23 December 2003 01:40
|To: xl7@yahoogroups.com
|Subject: RE: [xl7] Keeping midi tight
|Peace,
|Wesley
|Do you Yahoo!?
|Yahoo! Groups Links
I wasn't talking about an actual mod to the xx7, a mod to a cable coming out of it.  Electronically speaking, if x amount of bytes are trying to get out of the cable, having two different paths to flow through seems like would work.  Like I said, it's a unique fix for a unique problem, and yes an interface is certainly the way to go,(but they run around $300).
If you just have the xx7 sequencing several external mods and boards this trick could give you four cables.  My understanding of this is that it's a sort of dynamic allocation.  The sequences can spit out whatever you put into it, it just might not fit down the cable as fast as you'd like.  So splitting the cable into two should open up some room.
-Wesley
Do you Yahoo!?
2003-12-23 by Greg Waltzer
You realize that midi is a digital protocol, right?
No matter how many wires you connect, the same number of bits are going
to go through!
The transmission bandwidth is not limited by the wire, it is determined
by the transmitter.
And since it is specified in the midi standard, even if you could speed
it up, it would then be incompatible with any receiving device.
What was the original problem?
>-Wesley
2003-12-23 by Matt Picone
I certainly DON'T want to interpool the signals sent between midi
devices with a simple solder job. It's not smart at all.
Secondly, the logic here is all wrong. You're just cramming the same
data into 1 1/2 cables. All you're avoiding is the delay caused by midi
thru.
A midi splitter is a much smarter choice here. $35 or less on ebay.
-m@
2003-12-24 by mike
Mike G.
> -Wesley
> Do you Yahoo!?
2003-12-28 by psychogroove1
Matt is correct. Splitting the signal from a single Midi output by
adding a second pair
of cables seems suspicious to me. First, your cutting the signal
strength in half which
could add problems all it's own. Second, your allowing no more
information down the
sum of these now "TWO" Midi cables then you originaly had. And,unless
your feeding
to two seperate destinations and avoiding a through at some point,
there is no
advantage that I can think of.
psychogroove1
midi
> thru.
> -m@
2003-12-29 by Wesley D
you're exactly right.  It's a quick fix for a setup involving problems with using thru.
however, it could in theory save your ass or make you look like a hero some day.
-Wesley
Do you Yahoo!?
2003-12-31 by Aaron Eppolito
Output of the sequencer is bounded by the latency of the synthesiser.
Tracks are processed in numeric order, from 1 to 16 for all events up
till the current tick.  Firing complex synth notes can take a while
(relatively speaking) as opposed to sending MIDI notes which takes
really no time at all (from the sequencer's point of view).
Moral of the story?  Put your external tracks first if you can, cause
they won't affect timing at all.  After that, put the most important
timing critical tracks next (like drums, especially since they're
usually simpler patches).  Next put important melodic stuff, and
finally put fluffy stuff like pads last.
-Aaron
PS.  tons of controller data can chew up MIDI bandwidth, but internally
takes very little processor power.
PPS.  arps unfortunately have a lower priority than ALL of the
sequencer, so those'll get sloppy first.  You can record them with a
loopback cable if you want...  (yeah, I know it's a kludge)
PPPS.  MIDI A vs B out makes no difference.  (bonus trivia: on a
Proteus2000, the A *input* has a higher priority than the B input.)
> not.
> Mike G.
Do you Yahoo!?
Protect your identity with Yahoo! Mail AddressGuard
http://antispam.yahoo.com/whatsnewfree
2004-01-05 by erik_magrini@Baxter.com
Hey Aaron, two questions:
1. Can you explain how YOU would do the midi loopback recording of arps? I
had thought this would be a relatively simple thing to do, but after a
list member contacted me off list about this, we discovered we could only
get it to work via a pretty convoluted method.  I'll refrain from posting
it until I make sure I'm not missing something, but it's not as easy as I
had thought it would be.
2. What priority do the bts have?  The same as arps?
use of, or taking of any action in reliance upon, this information by
material from any computer.
For Translation:
