Sysex Remote Control
2003-12-19 by Matt Picone
Is it possible to select/queue patterns (during playback) remotely on a command station using sysex?
2003-12-20 by steve_the_composer
--- In xl7@yahoogroups.com, "Matt Picone" <matman@m...> wrote: > Is it possible to select/queue patterns (during playback) remotely > on a command station using sysex? I haven't done E-Mu sysex in months, but I seem to recall that there are no sysex transport functions available via regular sysex or by remote control sysex. You might be able to do it via remote sysex by paging through menus and cursor positions (button/knob simulation). I used this technique with two test projects: (1) automatically ramdomizing and saving a bank of presets (2) automatically storing multisetups in specific locations. The pattern view will allow you to cue the next pattern. 1. Place cursor under Next Pat value 2. Rotate the main knob 3. Press enter When the current pattern finishes, the queued pattern will start. That's basically it. If you have done remote control sysex programming, it shouldn't be too difficult. It may just take some time to develop the right algorithm for your needs. If you haven't, it will probably take a while. Caveat: I have done remote control programming on the P2500, but from what I can see it should be the same under any E-Mu running OS2.0. Footnote: I am in much need of income, so if you are interested in contracting out the programming, I would be happy to work on the project. (Contact me privately.) Hope this helps. --Dr. Steve
2004-01-23 by honkeyhindu
can someone explain why this does not work .... if i set up two patterns and record in a sequencer( sonar ) the events that i do .. ie the process in which i change the patterns ..when i go back and playback the sequence that i have recorded the pattern change does not take place .. there is definately a huge string of systex data recorded during the change but its does not take palce ..??? - In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@p...> wrote: > --- In xl7@yahoogroups.com, "Matt Picone" <matman@m...> wrote: > > Is it possible to select/queue patterns (during playback) remotely > > on a command station using sysex? > > I haven't done E-Mu sysex in months, but I seem to recall that there > are no sysex transport functions available via regular sysex or by > remote control sysex. > > You might be able to do it via remote sysex by paging through menus > and cursor positions (button/knob simulation). > > I used this technique with two test projects: > (1) automatically ramdomizing and saving a bank of presets > (2) automatically storing multisetups in specific locations. > > The pattern view will allow you to cue the next pattern. > 1. Place cursor under Next Pat value > 2. Rotate the main knob > 3. Press enter > When the current pattern finishes, the queued pattern will start. > > That's basically it. If you have done remote control sysex > programming, it shouldn't be too difficult. It may just take some > time to develop the right algorithm for your needs. If you haven't, > it will probably take a while. > > Caveat: I have done remote control programming on the P2500, but from
> what I can see it should be the same under any E-Mu running OS2.0. > > Footnote: I am in much need of income, so if you are interested in > contracting out the programming, I would be happy to work on the > project. (Contact me privately.) > > Hope this helps. > --Dr. Steve
2004-01-26 by erik_magrini@Baxter.com
Pattern Changes aren't transmitted as MIDI out.
honkeyhindu <honkeyhindu@...>
01/23/2004 10:55 AM
Please respond to xl7
cc: Subject: [xl7] Re: Sysex Remote Control can someone explain why this does not work .... if i set up two patterns and record in a sequencer( sonar ) the events that i do .. ie the process in which i change the patterns ..when i go back and playback the sequence that i have recorded the pattern change does not take place .. there is definately a huge string of systex data recorded during the change but its does not take palce ..??? - In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@p...> wrote: > --- In xl7@yahoogroups.com, "Matt Picone" <matman@m...> wrote: > > Is it possible to select/queue patterns (during playback) remotely > > on a command station using sysex? > > I haven't done E-Mu sysex in months, but I seem to recall that there > are no sysex transport functions available via regular sysex or by > remote control sysex. > > You might be able to do it via remote sysex by paging through menus > and cursor positions (button/knob simulation). > > I used this technique with two test projects: > (1) automatically ramdomizing and saving a bank of presets > (2) automatically storing multisetups in specific locations. > > The pattern view will allow you to cue the next pattern. > 1. Place cursor under Next Pat value > 2. Rotate the main knob > 3. Press enter > When the current pattern finishes, the queued pattern will start. > > That's basically it. If you have done remote control sysex > programming, it shouldn't be too difficult. It may just take some > time to develop the right algorithm for your needs. If you haven't, > it will probably take a while. > > Caveat: I have done remote control programming on the P2500, but from > what I can see it should be the same under any E-Mu running OS2.0. > > Footnote: I am in much need of income, so if you are interested in > contracting out the programming, I would be happy to work on the > project. (Contact me privately.) > > Hope this helps. > --Dr. Steve Yahoo! Groups Links To visit your group on the web, go to: http://groups.yahoo.com/group/xl7/ To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to: http://docs.yahoo.com/info/terms/ The information transmitted is intended only for the person(s)or entity to which it is addressed and may contain confidential and/or legally privileged material. Delivery of this message to any person other than the intended recipient(s) is not intended in any way to waive privilege or confidentiality. Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by entities other than the intended recipient is prohibited. If you receive this in error, please contact the sender and delete the material from any computer. For Translation: http://www.baxter.com/email_disclaimer [Non-text portions of this message have been removed]
