Importing / Sequencing module or keyboard sounds
2001-12-31 by NOLAbar10der@aol.com
Hey everyone. I'm a veteran keyboard player but a novice with the
groovebox-type machines. Can anyone simplify for me the process of recording
sounds from  my Korg Triton or N364 keyboards into the Xl-7's sequencer? I'm
sure that it's just a matter of MIDI channels, but I'm frustrated with trying
to learn it myself (manual is no help in the controlling department).  Once I
get that right, can I make a song or pattern using a track combination of
external sounds and internal E-mu presets?
 I know it might take a few minutes to type it, but any help is greatly
appreciated. Thanks!
Re: Importing / Sequencing module or keyboard sounds
2002-01-03 by sonicgraffiti
The only way this can be theoretically reproduced, is to copy midi
patterns into the XL-7 AND have it play back the sounds from your
Triton as well...this can also be reversed, using common MIDI
channels on both units, and setting one or the other as the
sender/receiver accordingly.
I beleive what your asking is for the XL-7 to achieve some kind of
sampling function, but it's not built that way (we're talking more
along the RS-7000 vein here).
sequencer?
This can be an illusion to novice MIDI users (not that you are
necessarily, but I'm using this example to make a point), that
somehow the sounds have been transported to the unit doing the
recording, but it helps to look at it as if the recording unit is
playing the source unit via remote.
>I'm sure that it's just a matter of MIDI channels,
You are correct, so you would want whatever sound will be layered on
the XL-7 with the sound on the Triton/N364, to be on these respective
channels on each unit.
>Once I get that right, can I make a song or pattern using a track
>combination of external sounds and internal E-mu presets?
Via MIDI data only, yes.
Hope that answers your questions... :o)
Steve Anthony
-late XL-1 owner (just sold), pending XL-7 owner (this weekend) WOOO-
HOOO!
