Saving Arp Question!
2001-12-28 by tommy_trance
I assigned Track 15 to Channel 15A Destination Both and have an XL-7 Arp pattern and set it to "ON" in preset edit mode. Then I realtime recorded that track using rubber pads. Then saved to preset. I now want to enable track 15 for Channel 15B also with destination Both and use the same XL-7 Arp pattern and now set arp to "OFF" in preset edit mode. This time I want to use Grid recording instead of realtime. I now saved my preset to another name other than what I had designated 15A. So I hope that when I hit track 15, both channels A and B should play simultaneously, one in Arp ON mode and the other in grid Arp OFF mode. Hmm, for some reason I can't figure out why both channels are affected by either on or off only and not have both playing at the same time. I made sure MIDI 15A is set to ON and MIDI 15B is set to on. So then I started using the "multi- setup" feature hoping that saving arp on/off to multisetup will solve the situation but it didn't work. I set arp ON for track 15 Channel 15A and arp OFF for Channel 15B in the preview mode then I saved it to the newly named Multisetup bank. I had already referred to page 101 in the manual but still couldn't figure it out! Anyone have any clue? I hope I am making sense here. :-) By the way, so far I've only been able to save factory arps, how do you save user arps? Thanks for any help!
