Low Digital output
Low Digital output
2003-12-03 by rajah_patel
hi
i used to have an XL7 now an XL1 -turbo
what i don't understand is why the SPdif digital out has such a low
output.
also if you want to sample sounds off it is it best to use the
Digital output and then normalize or should you just sample off the
analogue "Main outs"?
thank you kindly
Re: [xl7] Low Digital output
2003-12-03 by Aaron Eppolito
Quick lesson on digital audio math:
One full scale 16 bit sound = 16 bits.
Two full scale 16 bit sounds = 17 bits.
Four full scale 16 bit sounds = 18 bits.
128 full scale 16 bit sounds = 23 bits.
Difference in volume bewteen 16 bits and 23 bits = 42dB.
Essentially what all this means is that a 128 voice sampler needs to
have 42dB of headroom to ensure that no digital clipping occurs.
However, if you record the S/PDIF output, normalizing will *ALWAYS*
sound cleaner and be more high-fidelity than recording the analog
mains.  Always, always, always; no exceptions.  The same digital signal
that goes to the S/PDIF jack is the same one that goes to the D/A
converters.  It's not like there's a separate "gain-reduced" version
that goes to S/PDIF.  D/A then back through A/Ds NEVER improves
fidelity (though it may color the sound which may or may not be a good
thing).
--- rajah_patel <rajah_patel@...> wrote:
> why the SPdif digital out has such a low output.
> is it best to use the Digital output and then normalize
> or should you just sample off the analogue "Main outs"?
Do you Yahoo!?
Free Pop-Up Blocker - Get it now
http://companion.yahoo.com/
2003-12-03 by erik_magrini@Baxter.com
What if my S/PDIF cable is dirty though?
However, if you record the S/PDIF output, normalizing will *ALWAYS* sound
cleaner....
The information transmitted is intended only for the person(s)or entity to
which it is addressed and may contain confidential and/or legally privileged
material.  Delivery of this message to any person other than the intended
recipient(s) is not intended in any way to waive privilege or confidentiality.
Any review, retransmission, dissemination or other use of , or taking of any
action in reliance upon, this information by entities other than the intended
recipient is prohibited.  If you receive this in error, please contact the
sender and delete the material from any computer.
For Translation:
Re: Low Digital output
--- vibesart <vibesart@...> wrote:
> Great post Aaron. Given this neccesary situation w/re to headroom,
> does this mean that (presuming a 16 bit D/A) the "low level"
> S/PDIF signal is not a full 16 bits  - i.e. like 8-12 bits or
> something, given that level corresponds directly to bit depth in
> digital audio?
I think the S/PDIF is 20 bit, but I don't really recall.  It might be
24 bit, and it might depend on the S/PDIF / AES Pro setting in the
global menu.
> Is the D/A in the XL7 16, 20 or 24 bits?
24 bit, but converters never achieve the accuracy of their input.  Even
the best converters out there get about 18-20 bits resolution
(106-118dB SNR) and that's not even counting THD.
-Aaron
Do you Yahoo!?
> digital audio?
global menu.
-Aaron
Do you Yahoo!?
