e-loader - tracks in wrong order
2003-11-27 by phest2k
Hi all,
Problem:-
 I have an arrangment with less than 16 tracks in cubase -  lets say
tracks: 1,3,8 and 16 -- and then I export the midi file to say my pc
desktop then drage it onto my xx7 using e-loader, the tracks allways
get shuffled up to track 1,2,3 and 4 where track_1 is on ch.1, track_2
is on ch.3, track_3 is set to ch.8 and track_4 is set to ch.16.
--This is really annoying.
I was wondering if its my midi mode settings (omni poly etc)
 What i want is that track16 in cubase stays track 16 set to ch.16 on
my xx7 after downloading it via eloader. I suppose a workaroud in
cubase would be to use a 16 track default arrangement setup with dummy
notes on the tracks not being used. But this would also be time
consuming.
Any suggestions welcome.
I hope the above example could be understood.
Thx
:P aul
Re: [xl7] e-loader - tracks in wrong order
2003-12-01 by erik_magrini@Baxter.com
Best way to avoid this is to put in blank MIDI tracks as placeholders for
the tracks you're not using while still in Cubase.  IE, you'd want to
insert blank MIDI tracks set to MIDI channels 3, 5, 6, 7, 9, 10, 11, 12,
13, 14, and 15.  Then export the midi file and transfer it via E-Loader.
Hi all,
Problem:-
consuming.
Thx
:P aul
The information transmitted is intended only for the person(s)or entity to
which it is addressed and may contain confidential and/or legally privileged
material.  Delivery of this message to any person other than the intended
recipient(s) is not intended in any way to waive privilege or confidentiality.
Any review, retransmission, dissemination or other use of , or taking of any
action in reliance upon, this information by entities other than the intended
recipient is prohibited.  If you receive this in error, please contact the
sender and delete the material from any computer.
For Translation:
Re: e-loader - tracks in wrong order
2003-12-02 by phest2k
--- In xl7@yahoogroups.com, erik_magrini@B... wrote:
Thanks realm,
I thought that was the case.
Maybe my question should have been:
"why am i so lazy"
cheers
:P aul
placeholders for
to
12,
E-Loader.
> rEalm
> Hi all,
> Problem:-
track_2
on
dummy
> consuming.
> Thx
> :P aul
com/info/terms/
entity to
privileged
intended
confidentiality.
taking of any
intended
contact the
> For Translation:
