crashing when plugging in external keyboard/controller
2003-11-17 by trusolman
the first day i got the MP-7 i started sequencing right away and
decided to plug in my Oxygen-8 controller to play chords into the
machine. it instantly froze up and i had to restart it. i assumed it
was just a problem with plugging in the controller with the machine
on so i turned it off, plugged in the Ox-8 and then turned it on.
worked fine for a while, but noticed the MIDI in light constantly
flashing on the MP-7. also after several hours of sequencing (maybe
3) it froze up on me again. when i tried to erase some notes via the
erase button on the MP-7 and the keys on the Ox-8. the erase button
would not stay lit while the pattern was playing back, so i stopped
it and that was all she wrote. frozen! anyone else have similar
problems? is this something wrong with the MP-7 or does it sound like
the Ox-8 is creating the problem. i have not really tried the MP-7 by
itself for any extended period of time.
also to E-MU reps, can you guys update the OS to allow
copying/pasting of more than one track at a time? would make things a
lot easier.
Re: [xl7] crashing when plugging in external keyboard/controller
2003-11-17 by Aaron Eppolito
Sounds like you have a MIDI loop.  If you plug both the input and
output into the Oxygen, make sure it doesn't thru the in to the out.
-Aaron
Do you Yahoo!?
Protect your identity with Yahoo! Mail AddressGuard
http://antispam.yahoo.com/whatsnewfree
Re: crashing when plugging in external keyboard/controller
no loop. i only plugged the out of the OX to the in of the MP-7
> -Aaron
> Do you Yahoo!?
2003-11-18 by erik_magrini@Baxter.com
>>>Sounds like you have the MIDI Thru turned on in the MP-7, sounds like a
midi loop to me. ,<<
also to E-MU reps, can you guys update the OS to allow copying/pasting of
more than one track at a time? would make things a lot easier.
>>>You can use the "CUT/COPY Tracks to Clipboard" command for this. <<<
The information transmitted is intended only for the person(s)or entity to
which it is addressed and may contain confidential and/or legally privileged
material.  Delivery of this message to any person other than the intended
recipient(s) is not intended in any way to waive privilege or confidentiality.
Any review, retransmission, dissemination or other use of , or taking of any
action in reliance upon, this information by entities other than the intended
recipient is prohibited.  If you receive this in error, please contact the
sender and delete the material from any computer.
For Translation:
2003-11-20 by trusolman
i'll check on the midi loop thing, but is there something i'm missing
about the "cut/copy track to clipboard" feature? i only see where you
can cut/copy one track at a time to the clipboard. i have OS 2.0.
like a
copying/pasting of
> rEalm
entity to
privileged
intended
confidentiality.
taking of any
the intended
contact the
> For Translation:
Re: [xl7] Re: crashing when plugging in external keyboard/controller
2003-11-20 by khjkkkkk khjkhjk
maybe you should reinstall the OS.
sometimes it helps
like a
copying/pasting of
> rEalm
entity to
privileged
intended
confidentiality.
taking of any
the intended
contact the
> For Translation:
Yahoo! Groups Sponsor
Do you Yahoo!?
Free Pop-Up Blocker - Get it now
2003-11-20 by erik_magrini@Baxter.com
Check out page 94 of the revision "G" manual (in our files section if you
don't have it), it explains it pretty well.  It's not exactly what you're
looking for, but it would work for this too I think.
For Translation:
2003-11-29 by trusolman
i guess i haven't been making my question clear. i'll post in a new
message with subject line that addresses the specific question
if you
you're
> rEalm
missing
you
entity to
privileged
intended
confidentiality.
taking of any
the intended
contact the
> For Translation:
