swing quantize...
2003-11-11 by t_dubyah
I want to swing every other 1/8 note in my drum tracks. As I unserstand it, swing adjust every other note from the quantize setting... Correct. So to do this I would need to set my quantize to 1/8th notes. Correct? Well the problem comes in that I have ghost hits and what nots on 1/16 notes. Is there any way I can swing every other 1/8th without moving the 1/16s onto 1/8ths? Also when going for a more jazzy feel would you only swing the drums or swing the instruments as well. I would imagine most musicians just play with the drummer, whether his beats are on or off.
