EMU people!! 3/4 time is not working!
2001-12-24 by Ef Y
So i've tried more and it seems any pattern set to 3/4
time will not save.
If I turn the machine off or "Revert to saved
pattern", the time signature changes
it counts like this:
1.1 - 1.2 - 1.3 - 2.1 then back to 1.1
help!!
Frank
Do You Yahoo!?
Send your FREE holiday greetings online!
http://greetings.yahoo.com
Re: [xl7] EMU people!! 3/4 time is not working!
2002-01-02 by Aaron Eppolito
Ah... someone found this...  the shortest a pattern can be is 1536 ticks
(equivalent to one measure of 4/4 time).  For now, try using two measures if
you are going to work in a shorter meter than 4/4.
-Aaron
> time will not save.
> help!!
> Frank
> Do You Yahoo!?
