Arp random velocity
Arp random velocity
2003-11-05 by Christoph Kluxen
another thought...
Is there a way to setup a random arp velocity?
Or in other words is there a way to bring the Arp velocity chord from the
Preset Patchcords in the regular
Patchcords?
That would be too nice.
The more I work with that machine, there are some things I don´t like, for
example why runs grid edit
always with the measures, it would be much easier if it stops, also it seems
to be not possible to filter icoming
note data out, so that it get not recorded in any track.
Thanx,
Christ
NEU FÜR ALLE - GMX MediaCenter - für Fotos, Musik, Dateien...
Fotoalbum, File Sharing, MMS, Multimedia-Gruß, GMX FotoService
Jetzt kostenlos anmelden unter http://www.gmx.net
+++ GMX - die erste Adresse für Mail, Message, More! +++
Re: [xl7] Arp random velocity
2003-11-05 by erik_magrini@Baxter.com
That's what Loop Mode is for.  Check the manual on how to turn loop on and
off, and the shortcuts for setting the start and end point.
Re: Arp random velocity
2003-11-06 by steve_the_composer
> from the Preset Patchcords in the regular Patchcords?
By random arp velocity do you mean:
(1) a random velocity for a specific arp?
or
(2) a specific velocity for a random arp?
or
(3) something different?
What do you want arp velocity to control and/or be controled by?
There may be a solution to what you are trying to do, but it is not
clear (at least to me) what you are tring to accomplish.
--Dr. Steve
2003-11-06 by Christoph Kluxen
OK, that seems to be a more complicated question as I thought, so far I did
not really work much with arps,
so I don´t understand, what loop points have to do with it.
I meant
Usally I´m not too lucky with arps, cause they have no swing, so I try to
use it for external stuff to get
random volues as they trigger keysynced, so I want o edit the arp velocity
in the Preset Patchcords to realize
little bit random volume. (Don´t know if velocity played keeps there from
the arp, but....)
But I guess there`s no way,
Thanx,
Christoph
or
or
--Dr. Steve
Yahoo! Groups Sponsor
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> I meant
> (1) a random velocity for a specific arp.
> I try to use it for external stuff to get random volues as they
> trigger keysynced, so I want o edit the arp velocity in the Preset
> Patchcords to realize little bit random volume. (Don´t know if
> velocity played keeps there from the arp, but....)
I do not know of a way that you can have arps transmit notes with
ranomized velocities to an external synth via MIDI.
However, iF you want some randomness on how your arps notes sound to
the ear from the E-Mu sound engine, you can use patchcords.
Basic idea:
Velocity is simply one controller that can change different
parameters (such as volume, envelope, filter, etc.)
You can use XfdRand, KeyRand1, and KeyRand2 in layer level patchcords
to "randomly" change volume, evevelope, filter, etc. for each note as
it is played.
For each note played (either by hand or by the arpeggiator) these
random functions will change the sounds internally.
I will try to come up with a set of steps to demonstrate this, if it
would help.
Dr. Steve
Re: [xl7] Re: Arp random velocity
2003-11-07 by Christoph Kluxen
thanx a lot, I know the way in the patchcords, so you don´t have to explain
that.
There´s no simple Midi Tracker for the Mac, there´s an Atari emulator for
Mac, but just no Midi in. F..., I think I´´ll get an Atari by ebay, I don´t
like sequencers like Cubase or Logic. They make me sick.
Christoph
> I meant
Basic idea:
it is played.
would help.
Dr. Steve
                                  ADVERTISEMENT
Mac MIDI Monitor (was: Arp random velocity)
2003-11-07 by Aaron Eppolito
http://www.snoize.com/MIDIMonitor/
--- Christoph Kluxen <pocketd@...> wrote:
> There\ufffds no simple Midi Tracker for the Mac
Do you Yahoo!?
Protect your identity with Yahoo! Mail AddressGuard
http://antispam.yahoo.com/whatsnewfree
