made the switch to 1.18
2001-12-23 by mikexl7
Well installing the new OS went perfictly on windows ME using a
MidiQuest 2Port/SE.
I have sompthing to ask of ya all though on a different topic.
Alot of the time the patterns don't glitch now, I know since the
releace of 1.17 but they still do sometimes.  I have noticed that
when I am wrighting patterns that do glitch when switching if I turn
the thing off and back on the patternst switch with no problem.
What is this all about?
Is it rather anoying to have to reboot the thing just to see if the
patterns flow smoothly.  I would like to see this worked out.  The
amount of work being put into the XL/MP's is obvious and verry much
appreciated but this problem has been dragging on and on from OS to
OS.  I am a little concerned becouse I think the thing that you guys
at E-MU are working on now for the most part are the drivers for
windows to get the USB working.  I hope you have not overlooked this
problem that is still happening.
Peace
Mike
Re: [xl7] made the switch to 1.18
2001-12-23 by Scott Ruda
We know there are a few remaining 'rough' spots in pattern switching and
we are actively working on fixing them. (Well most people are off for
the next few weeks for holidays, but those issues are highest priority
for when everyone is back). Adding the USB support is not taking
significant resources away from fixes like this. We know that getting
sequencer timing right is very important. They are just not as easy to
fix as some of the other items that were in the recent releases which we
felt were important to get out as soon as they were resolved.
That being said, I'm not aware of your exact problem description having
been observed by anyone previously. We are aware that when switching
patterns in Song mode there is sometimes still a bit of a lag on the
first note of the switched-to pattern, and a couple of other
intermittent head-scratchers. But I think the behavior changing over a
power cycle is news to us. Can you verify this and give us some specific
steps to reproduce this? (You can send your info to me in offline e-mail
if you'd like).
You should expect a new release announcement around NAMM time (end of
January).
Scott
PS: Happy Holidays to everyone on the list!
Re: made the switch to 1.18
Thank you for looking at the board on the weekend you must be love
what you do! :)
well i hope that is the case anyway.
Well as for an example it is as simple as this...
I made a pettern containing quite a bit of info.  There are 11 active
tracks and five of them have program changes as well as a continuas
controller send for each of the five that contain program changes to
set the corect FX send.  All of this info is on 1.00.01 and this i
thought might be fair to add.
I then simply took the pattern and copied it to the next empty
pattern space and when I switch to the newly copied pattern the
glitch happens.  When I back to the original pattern from the copy
the glitch is not there.
A couple of weeks ago on impuls I got totaly fed up with this
happening and turned the thing off and on just to see what would
happen and the problem was gone.  Switching back and forth was no
problem.  I totaly don't understand this one, often i have a guess
but with this I rely don't understand.  Maby I will try reloading the
1.18 from scratch instead of loading it in on top of 1.17.  Would
this make any difference?
Thanks again scott.
Happy holidays.
Mike
switching and
for
priority
getting
to
which we
having
switching
over a
specific
mail
> if you'd like).
of
> January).
> Scott
2001-12-24 by erik_magrini@Baxter.com
Scott,
This happens to me as well.  Occasionally if I switch patterns while the
XL-7 is playing (in pattern mode, I never use song more), the next pattern
will "hiccup" a bit at the beginning.  Usually it's only the first couple
of beats, but it is noticeable if infrequent.  It seems to happen to me
the most if I've been working on a new pattern and then start switching
while it's playing.  If I just turn the XL-7 on and don't do any
recording/copying, then it doesn't seem to happen.  Like I said it's
infrequent, but when it does happen it's very noticeable.  I'll try and
narrow it down some more if I can over the next week.  I'm off work for
the holidays and plan on spending much of my time with just the XL-7 and
my new Red Sound Micro Sync :)
patterns in Song mode there is sometimes still a bit of a lag on the first
note of the switched-to pattern, and a couple of other intermittent
Re: [xl7] Re: made the switch to 1.18
2002-01-02 by Aaron Eppolito
The 01.01.001 time location is really only for use with external gear.  All
of the aforementioned things (prog. change, FX settings, etc) are
*automatically* stored at 01.01.000 by the sequencer for "internal" or "both"
tracks.  For those type of tracks, if you store duplicate info, it probably
will only cause problems.  The bottom line is, if you're not using "external"
tracks, you should never have to deal with the event editor to save pattern
state.
There is a known glitch with the new "edit pattern" feature.  We are working
on this at the moment (well, now that I'm back from vacation =).  If you've
saved the pattern, to get rid of the "editness", revert to the saved version
(but only after you've saved!).  This should remove the glitch.
This is because reloading (as accomplished by rebooting in this case) should
fix the problem.  The "revert" solution should do the same thing.
Nope.  There really is no such thing as loading from scratch.  That's only
for Windows... (and we all know that you never have to reload Windows,
right?)
> Happy holidays.
And a belated wish to you all as well!
-Aaron
