WARNING: My MP7 is unreliable
2003-10-25 by Tom Drunk
I got an MP7 and I got a problem with it.
First symptom: When recording a pattern, regardless of mode (ie
grid or realtime etc) or input trigger (ie. pads or external), my
notes often become gated or 'clipped' once entered. This
happens most frequently when I place a note at the first beat of
the first bar of a pattern. When the bar loops it seems that the
note at this point is either severely gated or totally missing. This
can happen with all types of ROM sound. The only way I can get
the sequencer to record the note and its value is to keep entering
it in record various modes whilst experimenting with different
quantise settings and tempo values until it sticks. This can be
very time consuming.
Note: I have experienced no problems when triggering MP&'s
ROM sounds live from both MP7 pads and external sources, it
'plays'  just fine. This prompts me to assume that there is a
problem with the sequencer and it's MIDI relationship with the
ROM set.
Second symptom: When doing a same-track overdub in real
time,  my previously recorded notes can become corrupted.
Gating often occurs, release points may wander and chord parts
seem to vanish. When I check the graphic note entry in grid
mode to see if everything is still in place it all appears fine and
as it was when originally entered, it just sounds wrong because
of the said random gating of notes.
These problems are intermittant, affecting about 1 in every 8
takes. Has anyone else experienced this?
Tried Remedies:
Firstly I did a full diagnostics test via the boot screen by the
usual
method: power up with cursors < and > held. I did all the tests
and they all came up without fault.
I thought that the sequencer may be crowded so I then did a
factory reset and discarded all pattern and user preset data.
I then laid a simple three track realtime pattern. To my fury the
bass drum immediately became very badly gated at the first beat
of my 4 bar loop. When building up a simple chord track with a
keyboard preset some notes beneath became gated.
I emailed EMU support who, normally being very helpful,
suggested an OS upgrade. I am still running V1.01 until I get  a
PC.
Surely this is not an OS issue as the EMU Command Station
was born out of a long and rich heritage of hardware
sequencers. I don't accept that a company such as EMU would
release a product line that required an OS upgrade in order to
properly fascilitate one of its basic functions: that of a rock
steady
sequencer. If this were to be the case then it would suggest that
EMU are prepared to supply an expensive piece of  dedicated
hardware without fully testing it first.
I am fully aware of  the occaisional note dop-out when using midi
sequencers. I have been using Akai MPC line for years and, like
with most supposed 'bombproof' sequencers, I still experience
the inevitable drop-out from time to time, but the problems I am
having with the MP7 surely shouldn't still be cropping up this
side of SP1200.
I shall of course update my MP7 OS soon but, in the meantime, I
would like to know:
Will I be wasting my time doing this whilst a more serious fault is
at play?
Who else has had these problems?
What else, apart from returning the unit to my dealer, can I do to
sort it out?
Please offer any advice that you might have. Thank You. . .
Re: [xl7] WARNING: My MP7 is unreliable
2003-10-25 by Aaron Eppolito
> my notes often become gated or 'clipped' once entered. This
> and as it was when originally entered, it just sounds wrong
> because of the said random gating of notes.
They are being *very* helpful.  Holding notes over the barline was
something that was fixed in a recent release.  Also, you do realize
that the XL-7 is always in overdub mode, right?  (for your OS at least,
Replace was also added in a later release).  Overdubbing the same notes
on top of each other is just asking for gating effects...
Go to your nearest music store or a friend's with a PC if you can't get
one.  Trust me (and E-mu support), 2.00 will fix your problems.
-Aaron
Do you Yahoo!?
Exclusive Video Premiere - Britney Spears
http://launch.yahoo.com/promos/britneyspears/
2003-10-26 by heyrag@netzero.net
The newest OS is going to fix all your problems. I have an MP7 and these issues went away with the upgrade. It sounds like your OS is very early on...thank your supplier. There have been several upgrades since the onset, each fixing some or many discovered bugs. 2.0 is the right choice- all previous fixes plus lots of new stuff. One thing worked well for me way back was copying the edited seq to a new location and then from the new location back to the original, ie, over write it with the copy...a pain but it works every time.
Record MP7 Audio with SoundBlaster Live
2003-11-05 by Cornell
I record audio from my mp7 to the computer which has a sound blaster live card. This stupid card won't record audio and vocal performance at the same time. It's either one or the other. The card won't let me select "line in" and "microphone" simultaneously. I don't have documentation for the card so I can't refer to that for information. I can't find what I need in the help menu either. Does anyone know something that I don't? Thanks in advance!
Do you Yahoo!?
Protect your identity with Yahoo! Mail AddressGuard
Re: Record MP7 Audio with SoundBlaster Live
2003-11-07 by magickal1718
Don't bother recording with a SB card. Invest in pro audio interface like the M-audio
line. You'll be glad you did.
> Do you Yahoo!?
2003-11-07 by joeyjojojuniorjohnson
Magic, its not all that bad! The s/n ratio and other tech specs of
the new audigy cards today is near matching that of
the 'professional' cards you talk of (terratec, turtle beach etc)
and the bundled software you get is excellent for the price.
The SbLive has 2 simultaneous inputs, and you should be able to
choose the option 'what you hear' in the SbLive mixer interface, or
advanced volume control record settings. This will mean the souncard
will record anything that is playing into it. So in theory you
should be able to use line & mic input at the same time.
Sorry I can't expand on that - its been ages since I used mine, got
no documentation to refer to after I sold it but I'm sure you can
record 2 sources at the same time.
Cheers
Jon
blaster live card.
same time. It's
and "microphone"
refer to that for
Does anyone know
> > Do you Yahoo!?
