Patterns not saving Preset changes
2003-10-23 by eviljim113
Ok...
I have a pattern with two Channels intended to be used.  Channel 1 is
the drum track that I recorded.  Channel 2 is some preset I chose and
recorded.
Before I record on Ch. 2, the default preset for that was Kit-10.  I
changed the preset to something like preset 33^3 and then recorded the
pattern.
After I made the recording, I saved the pattern and moved on.
Next day, I load up the pattern and found that Ch.2 still had preset
Kit-10 and not the preset I originally wanted.
This is getting frustrating because I've been dealing with this for
weeks.  Any idea what is going on here and how I could get the preset
to stick?  There are times the preset changes sticks but there are
some rare occurences where the presets do not stick.
The fix I found is I erase the whole track on Channel 2 and re-record
it again using the preset that I want.  That MOSTLY works but there
are times it doesn't.  Any ideas how I could make this work consistently?
Any help would be greatly appreciated.  Thanks.
Re: Patterns not saving Preset changes
2003-10-24 by eviljim113
Thank you lots!  Oddly, I only had one channel which the midi
program change is disabled.  That's why it was working for some
channels but not in others.
Thank you.
--- In xl7@yahoogroups.com, "phattcatuk" <oort@b...> wrote:
> This caught me out :)
> make sure midi prog change is enabled!!!
> under midi menu
