Index last updated: 2026-03-31 01:49 UTC
Polyrhythms ?
Polyrhythms ?
2003-10-15 by elemental
I know this is probably not possible...
but, is there any way of achieving polyrhythms in the XX-7?
That is one reason I am thinking of getting an RM1x or something just
for the polyrhythmic stuff.
Its not something I would use in every track, but live sequencing
would really lend itself to the use of different time signatures.
Re: Polyrhythms ?
2003-10-19 by robotchas
The obvious method, of running tracks of different lengths or time
signatures in parallel, is not possible on the XL7. You can cheat by
using longer sequences - for instance, a 12-bar pattern with tracks
in 3/4 and 4/4 - but this is clumsy and won't work in many instances.
You're in luck, though: what will work is to use the arpeggiators.
They'll loop at whatever length you determine, so you can easily play
different time signatures against each other. If the note or notes
triggering the arp are recorded into the pattern (instead of played
live), the arp will be retriggered each time the pattern loops, which
will throw this off. To avoid this, add a "sustain pedal=on" event
(CC #64 of >63) to your pattern so the note is held across the
pattern loop rather than retriggered. Now the polyrhythm will last
until you change patterns. Just watch out for stuck notes.
This should probably be added to the Tips and Tricks file, btw.
just
Re: Polyrhythms ?
2003-10-19 by elemental
Thanks for the info - I had a feeling the arpeggiators might come
into it.
What would make it really good would be if I could put shuffle
quantize on the arpeggiated patterns....
by
instances.
play
which
> just
Re: Polyrhythms ?
2003-10-20 by realm619
Agreed, I'll add it asap.
TnT: Using Arps for Polyrhythms [reply]
2003-10-20 by steve_the_composer
Excellent suggestion!!!!  Can't wait to get back into gear-based
composing/arranging to try this out. Thanks for sharing this
compositional TnT and for such a clear explanation.
--Dr. Steve
> by using longer sequences - for instance, a 12-bar pattern with
> tracks in 3/4 and 4/4 - but this is clumsy and won't work in many
> instances.
> play different time signatures against each other. If the note or
> notes triggering the arp are recorded into the pattern (instead of
> played live), the arp will be retriggered each time the pattern
> loops, which will throw this off. To avoid this, add a "sustain
> pedal=on" event CC #64 of >63) to your pattern so the note is held
> across the pattern loop rather than retriggered. Now the polyrhythm
> will last until you change patterns. Just watch out for stuck notes.
