Pattern Looping glitches in Cubase?
2001-12-21 by erik_magrini@Baxter.com
Lately I've been writing the basics of my patterns on the XL-7, and then I
use E-Loader to get the pattern data into my computer.  From there it gets
imported into Cubase 5.1 so I can fine tune things and draw the rest of it
in on the large screen.  I set it so that my L and R locators are on each
end of the pattern data, and then set it to loop 8 measures (the length of
the pattern).  But everytime it loops back to the beginning of the
pattern, playback stutters a bit, and it takes about 2 or 3 beats until it
gets synced up again.  I've tried a bunch of setting in cubase, and I've
never had this problem before with it working this way with other gear, so
I dno't think it's Cubase, but rather the XL-7.  Is it just getting too
much data at the beginning of the pattern?  I never have any glitching
when I switch patterns on the fly with just the XL-7, so that seems weird.
 Also, in Cubase I can mute all but a couple tracks, and I still get the
stuttering, so I don't think it's a MIDI bandwidth issue either.  What
exactly is being transmitted at the beginning of the pattern each time? Is
there sysex there, or is this part of that Tick 0 and Tick 1 issue? Anyone
else seen this?  Ideas?
I use the MIDI port on my Echo Layla24 BTW, if that matters at all.
Re: [xl7] Pattern Looping glitches in Cubase?
2001-12-21 by Lynn Bruington
the midi on the layla sux, get yourself a 2x2 midisport. i tried using the midi port on my layla and for some reason it always fucked up.
Sent: Friday, December 21, 2001 7:40 AM
Subject: [xl7] Pattern Looping glitches in Cubase?
Lately I've been writing the basics of my patterns on the XL-7, and then I use E-Loader to get the pattern data into my computer. From there it gets imported into Cubase 5.1 so I can fine tune things and draw the rest of it in on the large screen. I set it so that my L and R locators are on each end of the pattern data, and then set it to loop 8 measures (the length of the pattern). But everytime it loops back to the beginning of the pattern, playback stutters a bit, and it takes about 2 or 3 beats until it gets synced up again. I've tried a bunch of setting in cubase, and I've never had this problem before with it working this way with other gear, so I dno't think it's Cubase, but rather the XL-7. Is it just getting too much data at the beginning of the pattern? I never have any glitching when I switch patterns on the fly with just the XL-7, so that seems weird. Also, in Cubase I can mute all but a! c! ouple tracks, and I still get the stuttering, so I don't think it's a MIDI bandwidth issue either. What exactly is being transmitted at the beginning of the pattern each time? Is there sysex there, or is this part of that Tick 0 and Tick 1 issue? Anyone else seen this? Ideas?
Thanx, my girl has a 2x2 on her computer set up, I'll grab it and give it
a try.  This is the first time I've ever had any problems with the Layla,
bummer...
"Lynn Bruington" <nufleisch@...>
12/21/01 08:36 AM
Please respond to xl7
        To:     <xl7@yahoogroups.com>
        cc:
        Subject:        Re: [xl7] Pattern Looping glitches in Cubase?
Yahoo! Groups Sponsor
ADVERTISEMENT
RE: [xl7] Pattern Looping glitches in Cubase?
2001-12-24 by erik_magrini@Baxter.com
The Midisport worked fine, thanx for the advice!  Damn, now I gotta get me
a Midex 3 :)
----- Forwarded by Erik Magrini/MedDel/NA/Baxter on 12/21/01 09:05 AM
