What midi CCs do you map to?
2003-09-14 by dwoodaman
Since you seem to be able to map almost anything to anything, are
there some controllers that are better than others? Or any tips on
using these?
thx
Dana
Re: What midi CCs do you map to?
2003-09-15 by steve_the_composer
> using these?
I generally use predefined standards in two categories:
(1)  midi standards (pan, vol, espression, modulation, etc.)
(2)  machine/manufacturer conventions/defaults
If I need idiosyncratic CC #s, I make sure not to conflict with other
machine/manufacturer defaults, UNLESS I want one controller to affect
different parameters on different pieces of equipment.
Hope this helps.
Dr. Steve
