Presets and Patterns not saving!
2001-12-18 by erik_magrini@Baxter.com
I was working on a new pattern last night and I ran into an issue with the
XL-7 not saving Patterns or Presets, even though it said it had!  This was
the first time I've used OS 1.18 while writing a track, but I don't know
if that has anythign to do with it.  Anyway, I was working on a Pattern
and while doing so I created about 5 new Presets.  Each time I saved the
Presets individually before making the next one, and the Pattern was
playing back fine.  After working for a couple of hours, a friend stopped
by so I made sure all the Presets were saved again, then saved the Pattern
and powered off.  When I powered back on later that night, my pattern
wasn't sounding anything like it was when I powered off, in fact
everything that I had done during my last session was gone!  I could see
it if I forgot to save the Pattern, or maybe one Preset, but I lost all 5
Presets (and all my new Pattern data), none of them were where I saved
them (or anywhere in the USER Preset section, I checked thoroughly).  Is
this just me?  Was I in the Twilight Zone or something?  Has anyone else
had this happen?  I worked on it again and all was well when it was
powered off that time, weird.
Also, when I was spinning this weekend at a party, I brought the XL-7 out
to throw into my set too.  Occasionally, using the data wheel (when set to
Tempo Edit mode) caused the tempo to increment in values of 100, not 1!
Obviously this caused havoc with my sound, when my pattern would jump from
136 to 236 to 36 to 336 while I was trying to keep the XL synced to the
tables.  It didn't happen but a few times and behaved normally the rest of
the time, but it was enough to keep from bringing it into the mix again
after it did this a few times!  Is there a button combination I missed in
the manual that does this?  I wasn't spinning the wheel fast, just
incrementing it one click.  I still think we need the tempo to be
displayed in fractions of a whole number, no one needs a 1000BPM
range.....
Sigh, I hope my XL-7 isn't bad somehow, maybe I should reload the new OS
again?
