Notes stay in Grid recording
2001-12-17 by erik_magrini@Baxter.com
Well, it's not something that happens to me all the time, so it's been really hard to reproduce. Whenever I run into something that I think may be a bug, I always try and A) reproduce it, and B) write down exactly the key presses I did when I saw it. The joys of being a former beta tester for Roland :) Turns out this is a known issue that has to do with realtime recording with record quantize turned on. Not a big deal (Note List Edit allows you to delete it), and it'll be fixed soon. Thanx for checking though! rEalm Strange, after reading your comment, I tested out a pattern in 4 measures with arp on and recorded pad rhythm in realtime using quantize value of 16. Then I went into grid mode and record a few notes here and there in all 4 measures. Then I saved to pattern. Then I replayed the sequence and I can hear my grid notes. Then went into grid mode to see where they are located and it is clearly there also. I cleared the grid notes via pressing the track note button to mute like you did and it all seemed okay on my end. Did you try to create the same scenario with another pattern to see if it happens again?
