E-LOADER W2000 ...
E-LOADER W2000 ...
2001-12-17 by mewimewi
Sorry if my posts can influence other owners of MP7 ... and thanks
for maintaining that group ...   ;o)
I can't install E-Loader cause the installation process just after
launching the installation program ... I don't know why ... all the
rest is fine ...
MewiMewi
Re: E-LOADER W2000 ...
2001-12-17 by sigalarm
Same problem as reported earlier with Windows XP Pro.  This problem
has also been reported when using the JVM used by WebGain (Symantic
Cafe) as the default.  This is JDK 1.3.1 VM.  Same problem when using
WebLogic JVM as the default, a 1.2.2 VM.  All VMs used were Sun
release (not Microsoft).  The problem is that the installer will fail
before it even attempts to do anything with the application.
So its not really an ELoader problem, but a problem with
InstallAnywhere. (Install nowhere)
Bruce
--- In xl7@y..., "mewimewi" <mewimewi@m...> wrote:
> Hi,
> rest is fine ...
> MewiMewi
E-Loader Debug Run (Nerdy Bits)
Turns out that InstallNowhere will barf out a script of what it is
trying to do if you hold down the control key when you launch it.
For debugging purposes over at Emu, here is what is going on.
Seems that even though it finds the real Sun VM first, it decides to
use the Cafe one, and then it blows up because it can't munge the
classpath correctly (the ZeroG garbage can't)
Bruce
original working dir is: |C:\DOCUME~1\BRUCEH~1\LOCALS~1
\Temp\I1008614872\Windows
CONTROL KEY DOWN
application dir is: |C:\DOCUME~1\BRUCEH~1\LOCALS~1\Temp\I1008614872
\Windows|
app_path : |C:\DOCUME~1\BRUCEH~1\LOCALS~1\Temp\I1008614872
\Windows\ELoader_1.0_I
nstaller.exe|
arg 0: |C:\Download\ELoader_1.0_Installer.exe|
reading properties from: |C:\DOCUME~1\BRUCEH~1\LOCALS~1
\ELoader_1.0_Installer.lax|
Searching through the registry for VMs...
  looking in C:\jdk1.3.1_01\bin
    Found: C:\jdk1.3.1_01\bin\java.exe
    Found: C:\jdk1.3.1_01\bin\javaw.exe
    Found: C:\jdk1.3.1_01\bin\oldjava.exe
    Found: C:\jdk1.3.1_01\bin\oldjavaw.exe
  looking in C:\Program Files\JavaSoft\JRE\1.3.1\bin
    Found: C:\Program Files\JavaSoft\JRE\1.3.1\bin\java.exe
    Found: C:\Program Files\JavaSoft\JRE\1.3.1\bin\javaw.exe
...Finished searching through the registry for VMs
Searching through the path for VMs...
  Looking in C:\Program Files\Documentum\Shared
  Looking in C:\WINDOWS\system32
    Ignoring 'C:\WINDOWS\system32\java.exe' because it is in a
Windows System Di
rectory.
    Ignoring 'C:\WINDOWS\system32\javaw.exe' because it is in a
Windows System D
irectory.
    Ignoring 'C:\WINDOWS\system32\jre.exe' because it is in a Windows
System Dir
ectory.
    Ignoring 'C:\WINDOWS\system32\jrew.exe' because it is in a
Windows System Di
rectory.
    Found: C:\WINDOWS\system32\jview.exe
    Found: C:\WINDOWS\system32\wjview.exe
    Ignoring 'C:\WINDOWS\java.exe' because it is in a Windows System
Directory.
    Ignoring 'C:\WINDOWS\javaw.exe' because it is in a Windows System
Directory.
    Ignoring 'C:\WINDOWS\jre.exe' because it is in a Windows System
Directory.
    Ignoring 'C:\WINDOWS\jrew.exe' because it is in a Windows System
Directory.
  Looking in C:\WINDOWS\System32\Wbem
  Looking in C:\MSSQL7\BINN
  Looking in C:\PROGRA~1\DOCUME~1\Shared
  Looking in C:\VisualCafeXE\Java\Lib
  Looking in C:\VisualCafeXE\Java\Lib\SYMCLASS.ZIP
  Looking in C:\VisualCafeXE\Java\Lib\CLASSES.ZIP
  Looking in C:\VisualCafeXE\Java\Lib\COLLECTIONS.ZIP
  Looking in C:\VisualCafeXE\Java\Lib\ICEBROWSERBEAN.JAR
  Looking in C:\VisualCafeXE\Java\Lib\SYMTOOLS.JAR
  Looking in C:\VisualCafeXE\swing-1.1\SWINGALL.JAR
  Looking in C:\VisualCafeXE\Bin\Components\SFC.JAR
  Looking in C:\VisualCafeXE\Bin\Components\SYMBEANS.JAR
  Looking in C:\VisualCafeXE\Java\Lib\DBAW.ZIP
  Looking in C:\VisualCafeXE\Bin\Components\DBAW_AWT.JAR
  Looking in C:\VisualCafeXE\Bin\Components\Databind.JAR
  Looking in C:\VisualCafeXE\Java\Lib\servlet.jar
  Looking in C:\VisualCafeXE\Java\Lib\webserver.jar
  Looking in C:\VisualCafeXE\Bin\Components\templates.jar
  Looking in .
  Looking in C:\VisualCafeXE\Java2\Bin
    Found: C:\VisualCafeXE\Java2\Bin\java.exe
    Found: C:\VisualCafeXE\Java2\Bin\javaw.exe
    Found: C:\VisualCafeXE\Java2\Bin\oldjava.exe
    Found: C:\VisualCafeXE\Java2\Bin\oldjavaw.exe
  Looking in "C:\Program Files\Common Files\WebGain Shared"
Directory.
Directory.
Directory.
Directory.
  Looking in C:\WINDOWS\COMMAND
  Looking in C:\PROGRA~1\DELL\RESOLU~1\COMMON\BIN
  Looking in C:\VisualCafe\Bin
  Looking in C:\VisualCafe\Java2\Bin
  Looking in "C:\Program Files\Common Files\Symantec Shared"
...Finished searching through the path for VMs
ORDERING VMS
1: C:\WINDOWS\system32\jview.exe (in path)
2: C:\WINDOWS\system32\wjview.exe (in path)
3: C:\VisualCafeXE\Java2\Bin\java.exe (in path)
4: C:\VisualCafeXE\Java2\Bin\javaw.exe (in path)
5: C:\VisualCafeXE\Java2\Bin\oldjava.exe (in path)
6: C:\VisualCafeXE\Java2\Bin\oldjavaw.exe (in path)
7: C:\jdk1.3.1_01\bin\java.exe (in registry at
HKEY_LOCAL_MACHINE\SOFTWARE\JavaS
oft\Java Development Kit\1.3)
8: C:\jdk1.3.1_01\bin\javaw.exe (in registry at
Soft\Java Development Kit\1.3)
9: C:\jdk1.3.1_01\bin\oldjava.exe (in registry at
vaSoft\Java Development Kit\1.3)
10: C:\jdk1.3.1_01\bin\java.exe (in registry at
Soft\Java Development Kit\1.3.1)
11: C:\jdk1.3.1_01\bin\javaw.exe (in registry at
aSoft\Java Development Kit\1.3.1)
12: C:\jdk1.3.1_01\bin\oldjava.exe (in registry at
avaSoft\Java Development Kit\1.3.1)
13: C:\Program Files\JavaSoft\JRE\1.3.1\bin\java.exe (in registry at
HKEY_LOCAL_
MACHINE\SOFTWARE\JavaSoft\Java Plug-in\1.3.1)
14: C:\Program Files\JavaSoft\JRE\1.3.1\bin\javaw.exe (in registry at
HKEY_LOCAL
_MACHINE\SOFTWARE\JavaSoft\Java Plug-in\1.3.1)
15: C:\Program Files\JavaSoft\JRE\1.3.1\bin\java.exe (in registry at
HKEY_LOCAL_
MACHINE\SOFTWARE\JavaSoft\Java Plug-in\1.3.1_01)
16: C:\Program Files\JavaSoft\JRE\1.3.1\bin\javaw.exe (in registry at
HKEY_LOCAL
_MACHINE\SOFTWARE\JavaSoft\Java Plug-in\1.3.1_01)
17: C:\Program Files\JavaSoft\JRE\1.3.1\bin\java.exe (in registry at
HKEY_LOCAL_
MACHINE\SOFTWARE\JavaSoft\Java Runtime Environment\1.3)
18: C:\Program Files\JavaSoft\JRE\1.3.1\bin\javaw.exe (in registry at
HKEY_LOCAL
_MACHINE\SOFTWARE\JavaSoft\Java Runtime Environment\1.3)
19: C:\Program Files\JavaSoft\JRE\1.3.1\bin\java.exe (in registry at
HKEY_LOCAL_
MACHINE\SOFTWARE\JavaSoft\Java Runtime Environment\1.3.1)
20: C:\Program Files\JavaSoft\JRE\1.3.1\bin\javaw.exe (in registry at
HKEY_LOCAL
_MACHINE\SOFTWARE\JavaSoft\Java Runtime Environment\1.3.1)
Searching for console vm.
lax.nl.valid.vm.list=J2 J1 MSJ MRJ
lax.nl.current.vm=.
 was not a valid Win32 executable.
C:\WINDOWS\system32\jview.exe does not match J2 or it is not a
console app and I
 need a console one.
C:\WINDOWS\system32\wjview.exe does not match J2 or it is not a
console app and
I need a console one.
SUCCESS! C:\VisualCafeXE\Java2\Bin\java.exe
BATCH SCRIPT
cd "C:\DOCUME~1\BRUCEH~1\LOCALS~1\Temp\I1008614872\Windows"
set CLASSPATH=C:\DOCUME~1\BRUCEH~1\LOCALS~1\Temp\I1008614872
\InstallerData\lax.j
ar;C:\DOCUME~1\BRUCEH~1\LOCALS~1\Temp\I1008614872
\Windows\resource\jdglue.zip;C:
\InstallerData\IAClasses.zip;C:\DOCU
\InstallerData\Installer.zip;C:\DOCUME~1\
BRUCEH~1\LOCALS~1\Temp\I1008614872\InstallerData;
C:\VisualCafeXE\Java2\Bin\java.exe -Djava.compiler=OFF -noverify
com.zerog.lax.L
AX C:\\DOCUME~1\\BRUCEH~1\\LOCALS~1\\Temp\\I1008614872
\\Windows\\ELoader_1.0_Ins
taller.lax C:\\DOCUME~1\\BRUCEH~1\\LOCALS~1\\Temp\\env.prop
executing java...
Addition to the Task Manager's Applications tab: SUCCESS
Warning: JIT compiler "OFF" not found. Will use interpreter.
Exception in thread "main" java.lang.NoClassDefFoundError:
com/zerog/lax/LAX
Press any key to exit...
