Just for kicks...
2003-08-21 by erik_magrini@Baxter.com
So, what are the top 3 features people would still like to see it make it into a new OS. I know it probably won't happen, but if it was possible, what would you like to see? Here's mine: 1. No actions require the sequencer to stop. Things like Quantize, transpose, Erase Track etc will all be possible without automatically stopping the sequencer. Real-time preview of Quantize and transpose settings ties into this I think. 2. A Revert To Saved Pattern shortcut key command. (Edit+Pattern?). 3. A way to assign the knobs in Program mode to control Effect parameters, WITHOUT having to set the effects to be controlled by "Preset on Channel x". Maybe this is already possible? rEalm (I'm cheating and adding a 4th I can't believe I almost forgot, Snap Mode for the knobs.) [Non-text portions of this message have been removed]
