Problems with mp7
2001-12-15 by Alex Jacobi
Hi erverybody, after working some days with my new MP7 i have some questions? * i programmed a few patterns as basic sequences for a track using internal sounds and while switching from one pattern to another it gets out of tempo(the pattern starts to late it sounds like its hangin for some time). the patterns use the same presets. Switching back to the 1st pattern makes no glitch. I�m unable to perform tracks on stage with these tempoglitches. Even a Alesis MMT8 i recently used, had no problems doin this.I�m not using cc�s or aftertouch in this track I read in the archive that some of you had this problems earlier, are there some workarounds? *why does the sequencer writes controllers like 79, 80 ... into every track in every pattern? CC79 messes all my e4x outputsettings. i have to delete them manually. Also i dont see them in the pattern edit event lists. i�d like to be able to see wich controllers are in what pattern. the same happens with the quickedit knobs. i dont find any window, where i can see in what startvalue they are saved in the pattern. *in the patterns mentioned before, i have on a track a bassdrum wich sometimes mutes , sometimes not. this is not reproduceable and happens not when i listen to it alone. alex
