XL-7 + Laptop = Live PA ??
2003-08-16 by adz32
Hi people,
I've been researching a good Live PA setup, and concluded that the XL-
7 should be a part of it. I now have a 2nd hand one on its way to me
now. ($280 on e-bay - not bad eh?)
I am planning my setup to be basically just the XL-7 and my laptop,
which will be running a VST host such as Muzys (which I have yet to
look into properly) and possibly Ableton Live for sequencing pre-
recorded loops. I will have Reaktor and Kontakt as my main sound
sources. I am not planning on using the XL-7 onboard sounds that
much, not at this stage anyway. Maybe for kik+hats or something, and
for backup in case of a crash.
I will probably expand this with a mixer + synth + outboard fx, but
only after success with the above setup.
Does anyone use this kind of setup?
A.
Re: [xl7] XL-7 + Laptop = Live PA ??
2003-08-17 by Your Name
> I am planning my setup to be basically just the XL-7 and my laptop, <BR>
> which will be running a VST host such as Muzys (which I have yet to <BR>
> look into properly) and possibly Ableton Live for sequencing pre-<BR>
> recorded loops. I will have Reaktor and Kontakt as my main sound <BR>
> sources. I am not planning on using the XL-7 onboard sounds that <BR>
> much, not at this stage anyway. Maybe for kik+hats or something, and <BR>
> for backup in case of a crash.<BR>
That's a whole load of cpu power you are going to need... You might want to
back off a little, unless you have a really heavy duty laptop in mind.
I run my xl-7 with a laptop, and my live looping rig. When I can't bring the live
instrument and gear, I just use the laptop and xl-7, and an oxygen controller.
Has anyone else noticed that midiman is naming it's keyboard range after
software piracy groups?
bIz
Re: XL-7 + Laptop = Live PA ??
2003-08-17 by adz32
might want to
mind.
bring the live
controller.
after
> bIz
I've got a 2.4 Ghz Sony, should be enough for most situations. I
wonder how I'll be able to push it within safe limits...
RE: [xl7] Re: XL-7 + Laptop = Live PA ??
2003-08-17 by Stu
You should have enough power. The only real issue is things like windows,
and the physical build quality of your laptop.
The problem with windows is if your laptop does crash, it takes bloody ages
to reboot, compared to a piece of hardware. Windows 2000/XP is a lot more
stable than win9x used to be, but never underestimate Murphy and his Law...
Secondly, laptops aren't designed to take much abuse, unlike most musical
gear, so you're gonna have to be gentle with it.
Thirdly, in the unlikely event your laptop gets nicked, that's over a $1000
down the drain, compared to $100's of dollars if someone nicks your
electribe or SP505 etc, but if your gear is racked up, they gonna have a
hard time nicking it in the 1st place.
Sorry to be so negative, but you gotta be aware of these possibilities, coz
they can and do happen.
Stu
  Sent: 17 August 2003 11:34
  Subject: [xl7] Re: XL-7 + Laptop = Live PA ??
  might want to
  mind.
  bring the live
  controller.
  after
  > bIz
        Yahoo! Groups Sponsor
              ADVERTISEMENT
2003-08-17 by Nick Rothwell
For a year or two I've been using a setup based round laptops, Magma
expansion chasses, and Korg OasysPCI cards, plus Nord MicroModulars,
all controlled by a CM Motor Mix surface. The setup works well with
the XL-7 as a clock source and an occasional sound source, and the XL
is a really good scratchpad for working developing ideas, although
I'll often manually port XL sequences into Max/MSP so I can transform
them while they're playing. I tend not to like composing with
sample-based sound sources (in fact, I work a lot with effects
processing) so the XL-7 sound engine is, by and large, a library which
I visit from time to time; more heavily for commercial commissions.
For native laptop audio (i.e. not outboard DSP like the Oasys cards)
you might have to watch your latency, especially if you start bringing
in low-latency audio from the XL, but otherwise it should work; I know
a lot of people working this way.
  nick rothwell -- composition, systems, performance -- http://www.cassiel.com
2003-08-18 by erik_magrini@Baxter.com
Yeah, I thought that was pretty funny myself.
bIz
RE: [xl7] XL-7 + Laptop = Live PA ??
2003-08-18 by Stu
It's clever if you ask me...
Some script kiddie does a search for Oxygen Cubase SX, and in the middle of
their list is Midiman Oxygen Controller... just what they need to control
the VSTi's in their ill-gotten copy of SX! ;)
Stu
  Sent: 18 August 2003 13:33
  Subject: Re: [xl7] XL-7 + Laptop = Live PA ??
  bIz
I've been researching a good Live PA setup, and concluded that the XL-7
should be a part of it. I now have a 2nd hand one on its way to me now.
>>>Great deal! <<<
I will have Reaktor and Kontakt as my main sound sources.
>>>You're a braver man than me! :)  As much as I love Reaktor, it crashes
far too often for me to ever think of it as a live tool.  You're idea of
using Ableton's Live is spot on though, great program for live sets. <<<
2003-08-18 by adz32
Yeah, I'm not sure how Reaktor will stand in a live situation,
although I hear the Windows standalone version is very stable now.
I'll be wanting to use the VST version ideally, but at the moment its
not yet stable enough. Maybe in the next release....(hopeful).
Brownboy on LivePA.org was raving about it saying it was now his main
synth, but that was a week after he got it, and whether he uses it
live I dont know....
crashes
idea of
sets. <<<
> rEalm
Re: [xl7] Re: XL-7 + Laptop = Live PA ??
If you were just playing back simple ensembles then it would probably
work.  I wouldn't want to do much heavy tweaking/editing in it live
though, as that's when it seems to crash on me the most frequently.
adz32 <adz32@...>
08/18/2003 08:57 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
crashes
idea of
sets. <<<
> rEalm
2003-08-18 by adz32
Yeah tell me about it.... but usually, if I just set up a few good
tweakable params to MIDI CC's it works ok. I wouldnt dare start
fiddling with an ensemble through Reaktor's interface in a live
situation though... that'd be asking for it.
I guess the real answers will be revealed when I actually start
putting together + practicing a live set (i.e. when my XL-7
arrives!!) Should be interesting... I've never ventured into live
electronic performance before, nearest i've got is jamming with
filter and envelope tweaks in the studio.
-A.
probably
> rEalm
> adz32 <adz32@y...>
> 08/18/2003 08:57 AM
>         cc:
its
main
> crashes
> idea of
> sets. <<<
> > rEalm
2003-08-18 by keiodi
--- In xl7@yahoogroups.com, "Stu" <routerman@z...> wrote:
[clip]
possibilities, coz
> Regards,
> Stu
Yeah just ask BT.
I really try to watch my stuff like a hawk.  but it can get
complicated when you have 2 racks full of gear and a number of desk
top units plus a mixer.  and you have to get off stage and let
someone else on.  luckily I haven't lost anyhting yet (well someone
yoinked my 45 adapters from my turn tables when I was spinning but I
wasn't at the tables the whole time.  It was probablly one of the
other DJ's.
my computer for live PA is a 4U rack mounted monstorsity the case
itself weighs 30 lbs. I haven't wieghed it since I installed
everything but it is heavy.  I guess that if someone were gonna try
to take somethingg it would be my EA-1 The XL7 is pretty big and it's
frickn' yellow.  try to hide that.  ;)
2003-08-18 by Oscar Finch
My advice in live use would be this .
Render any Reaktor voices and other softsynths to audio on the HD itself.
Transfer all of them over for use in Abelton live.
Use the Laptop running Albelton Live + the Command Station (never underestimate the power of an Electribe or two in alive set with a laptop either) .
Keep it as simple and as CPU underloaded as possible and you should not have any problems.
PS: I get my Command Station next week :P .
Any OZ residents interested in an RS7000 (mint never gigged) w/full ram SM card read/writer ,64meg SM card ,all utilities ,manuals and SCSI type 1 cable) - hit me up OK .
_______________________________________________
Join Excite! - http://www.excite.com
The most personalized portal on the Web!
2003-08-19 by adz32
I was originally thinking of doing it this way, but the idea of
having everything as a pre-recorded loop seems really un-live... I
want to be able to tweak as much as possible in realtime. That way
you have as much control over the music (and the crowd) as possible.
BUT - I do agree it would be safest just to render everything.
itself.
laptop either) .
2003-08-19 by erik_magrini@Baxter.com
Because Live lets you assign and use plug ins for the audio tracks, you'll
still be able to tweak your parts if you want.  The included plug ins
alone are very CPU light, and stable too.  If you really want to get the
most out of that kind of set up, you could infact assign almost everything
on the XL-7 to control Live.  I set it up so that the key pads were muting
and unmuting tracks, Triggers would select new parts etc.  You could do an
entire laptop based set without ever touching the laptop itself with that
program.
A lot of people seem to forget that aside from being a really great synth
and sequencer, the XX-7's are also very nice control surfaces too.  :)
adz32 <adz32@...>
08/19/2003 04:07 AM
        cc:
itself.
laptop either) .
2003-08-19 by adz32
Hmmm .... looks like i'll have to look into Live then.... but you
still can't tweak sounds from the inside like that, e.g. envelopes
etc. I will just have to try and find a compromise.
BTW I found out that RT Player (VST host for PC) is going to be
released with ReWire support soon... its also now available without
the controller/dongle thing. Looks like it might be a contender for
holding a soft synth/sampler or two for a live situation, ReWired
into Live :- www.dsound1.com
A.
you'll
ins
get the
everything
muting
could do an
with that
> program.
synth
too.  :)
> rEalm
Playing live is 100% about compromises actually.
Stabilty vs. Tweakability
Repeatabiltiy vs. Spontanaity
Beerility vs. Yagerbombability
Ealm
Hmmm .... looks like i'll have to look into Live then.... but you still
can't tweak sounds from the inside like that, e.g. envelopes etc. I will
