Custom RPS triggers question for mR. rEalm
2003-08-15 by dwoodaman
Yo - I just re-read your idea for custom triggers remember this? "Here's the fun part. You would need to select a blank Pattern, preferably one you've set up already as a "template" Pattern that you use as a starting place for composing all of your Patterns with. Now assign that Preset you created to MIDI channel 1B (or whatever channel you want to use) and save the Pattern. I assume that most of us typically just use the MIDI A channels, so this leaves us 16 "B" channels for our phrases. So Trigger 1 would be a Preset on MIDI 1B, Trigger 2 would be a Preset on 2B, etc. Now you would go into the Controllers Menu, and set your first trigger to MIDI channel 1B, and the trigger note as the one you pressed from the second paragraph above. Now when you press that trigger button, it will sound your drum Pattern! " Really great idea but one question: if I set up this way, wont I lose the ability to trigger the normal A channels with the trigger buttons? I mean I would miss being able to drop in/out my normal BD part, or snare part, etc, that are on the A channels. Thanks much dana
