!!!!HELP!!!! Using the Xl- 7 with new pure phatt rom
2003-08-06 by ReeScree
I currently using my XL-7 with Cakewalk Sonar and i'm trying to make
Sonar read the xl-7 rom and the pure phatt rom but it only reads my
user rom. can anyone help me please, its driving me crazy!!!!!!!!!!
Re: !!!!HELP!!!! Using the Xl- 7 with new pure phatt rom
2003-08-06 by xromxx7
make
Hi ,
Are you using a valid instrument definition (.ins file) ? Or simply
the right one ? Are you defining correctly which instrument
definition you wanna use with each midi tracks in SONAR ? We do need
more details before one can help you with efficiency !!
(MSB for user's bank access is 0 for all EMU modules, that's why you
can get it even with a generic .ins file or a wrong one....but every
rom module has its own ID number, for example XL7 MSB is 14, BEAT
GARDEN MSB is 67 and so on , so you have to use the right definition
file with the midi track where you want all your sounds listed !!)
Hope this helps in some way......
Good luck !
XROM
2003-08-07 by ReeScree
> make
my
crazy!!!!!!!!!!
> Hi ,
need
you
every
definition
> Good luck !
> XROM
Yes that kind of helps.  I'm sorry  about being so vague earlier.
I'm kinda of new to this so bare with me if you can.  What I'm trying
to do is patch into my rom(s) if possible.  B4 I put in the new rom i
was working strictly of off my user setting and all of its banks and
the user settings when right out of the box is the same as the xl-7
rom right.  So now I have a new rom with new sounds but when I go to
Sonar I can only control my user setting and not my new set of
sounds.  I want Sonar to switch from my xl-7 rom to the pure phatt
rom  through at will.  Strictly using my command station as a slave
unit.  I hope this explains my situation a little better.  Help me
please!!!!!!!
2003-08-08 by xromxx7
> sounds.
This means you are using a wrong instrument definition file, in order
to access XL7 & PURE PHATT sounds in SONAR you need to use their
relevant Cakewalk intrument definition files and affect them to the
desired midi track !!
Now what you should do is :
-1 : go to the files section of this Group and search for the
Cakewalk .ins File named P2k_all, download it...
-2 : Launch SONAR and select the first MIDI track where you want your
sounds listed > right Click on it > Choose TRACK PROPERTIES in the
Pop up menu, you should get the Track properties Window > Click on
INSTRUMENTS you will see the Assign Instruments Window > Click on
DEFINE then Click on IMPORT , select your P2K_all instrument
definition....then select XL7 and Pure Phatt...
-3 : Now back to the ASSIGN INSTRUMENTS WINDOW where you click on
MIDI track 1 (left side) then either XL7 or Pure Phatt (Right side)
up to you , doing this you affect a midi track with the desired
instrument definition (say for example XL7, so now you will have
access to XL7 banks on MIDI track 1)..........
Repeat step 3 for all other MIDI tracks
-4 : Back to the arrange Window choose channel, bank & patch for
every midi channel and TADAAA !! look at your XX7 LCD it should move
accordingly (I hope for you !)If it doesn't.....Buy yourself a
Xylophone because the Gods are against you (at least the ones that
deal with computers!)
May fortune be with you !
XROM
> > sounds.
One last thing I forgot to mention , very important, when you right
click on a midi track and get the TRACK PROPERTIES window, always
check that the pop up menu named BANK SELECT METHOD is set to normal,
if it's not, you will only be able to select user patches even with
the right instrument definition !!!
Again good luck !
XROM
