when you eload a pattern into the comp and save .mid.....
Re: [xl7] when you eload a pattern into the comp and save .mid.....
2003-08-02 by Aaron Eppolito
It should be ratained.  It's a 72 byte (if I remember right) sysex
message on track 0.
-Aaron
--- flaviotronic <cracktastick@...> wrote:
> does it also save the effects processor information? and if not,
> what must i do to save that? any help would be much apprechiated,
> thanks.
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
2003-08-03 by [Mowah]
Indeed.
And I've found each track has a bank select message to retain the Preset
used, along with a couple of Control Changes: CC79 (output assigned for
that part) and CC80 (arpegiator status).
Unfortunately - if I'm not mistaken - these CC are not updated if the
Preset has not been changed back and forth as well on a previously saved
and then edited part. Which means any change of output is lost.
I would have like a big SysEx string for all these settings, including
temporary edited patches as well. Much more easy to deal with than
having to save a patch on user location because it has been slightly
altered.
Oh well. 8)
> message on track 0.
Sebastien,
A computer's attention span is as long as it's power cord.
2003-08-04 by Aaron Eppolito
> saved and then edited part. Which means any change of output is lost.
That shouldn't be the case.  Every time you save, it stores the current
settings (all the necessary program changes, cc#79 & 80, etc...)
-Aaron
Do you Yahoo!?
2003-08-04 by erik_magrini@Baxter.com
Yes, it saves that as well.
08/02/2003 04:38 PM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] when you eload a pattern into the comp and save .mid.....
thanks.
2003-08-04 by [Mowah]
Duh! My mistake.
It saves the settings all right even though the pattern is not
considered "dirty" when these parameters are edited, hence the
Save/Copy green led does not flash, hence me being confused.
Thank you very much Aaron. :)
Sebastien,
Walls impede my progress
