Wiardgroup
Index last updated: 2026-04-28 23:41 UTC
Any problems using the JAG with a 5 volt system (euro)?
Re: Any problems using the JAG with a 5 volt system (euro)?
2006-10-06 by Grant Richter
Why do you say the euro system is 5 volt?
The standard set by the Arp 2600 is that all mini-jack systems should be 10 volt control
range systems. I know the following follow that: Wiard 300 and 1200, All Blacet modules,
PAIA 9700 modules, ARP 2500/2600, Roland 100 and 100m, Aries 3xx modules.
Did something get changed in the designs from european module makers?
--- In wiardgroup@yahoogroups.com, "wiard300" <wiard300@...> wrote:
> I am considering buying a JAG to use with my "euro" modular. Are there
> any possible issues? I would probably run an LFO thru it, as an example.
> thanks,
> RSA
2006-10-06 by andrew dalio
Perhaps, but I've never had any problems using my Wiard 300 series
modules along with Doepfer, Analogue Solutions, Moog Voyager, even my
MS 20 (as long as I wasn't driving oscillators). Just experiment, and
you'll do fine...
-andrew bunny
--- In wiardgroup@yahoogroups.com, damon <damon@...> wrote:
>  From Doepfer's technical page:
> Control voltages, as produced by modulation s sources like the LFO
> and ADSR, are from -2.5 V to +2.5 V (5 VSS) for the LFO, and from 0 V
> to +8 V for the ADSR.
> Plan B's envelope is +8v
> Cwejman's envelopes are only +5v
> Analogue Systems is like Wiard, 100m, etc.  However, not all Blacet
> is 10v.  The two Quad VCAs I've bought over the years have a 5v ceiling.
> > modules.
> > there
> > example.
> > > thanks,
> > > RSA
Re: [wiardgroup] Re: Any problems using the JAG with a 5 volt system (euro)?
2006-10-06 by damon
> modules.
> there
> example.
> > thanks,
> > RSA
2006-10-07 by Mark Griffiths
Hi, the old QuadVCAs are 1-10V but can be modified to 0-5V, the new ones, starting September this year, are 0-5V..so, yes, seems odd.
regards, Mark
?? Odd, the Blacet Quad VCA I built up the other month was 10v, but could be modified by cutting traces and adding resisitors to work at 5v
2006-10-07 by p. hendricks
posted on the Doepfer list Fri Jul 7, 2006:
As long as the voltages applied to any socket are within -12V...+12V we
guarantee that nothing can be damaged within the A-100. But even voltages
beyond these limits will not damage most of the inputs (e.g. audio inputs
and CV inputs with attenuators). But there is one exception: inputs and
outputs of modules that use voltage controlled switches (e.g. A-150, A-151,
A-152, A-154, A-155, A-148), older versions of A-150 and A-151
(max. -8V...+8V), and CV or audio inputs without attenuators. For these
in/outputs the voltages applied should be within -12V...+12V.
Best wishes
Dieter Doepfer
2006-10-08 by Grant Richter
Thank you all for that useful information. I believe I understand now.
Each Wiard module in the 300 and 1200 series has a 1K limiting resistor on the output of
the op-amp or transistor Class A buffer. This limits the output current to a safe level, even
in the even of a complete short (like when a patch cord touches a faceplate during normal
patching). They also protect the outputs if two outputs are connected together (see
below).
Lets do a tiny bit of math. By Ohms law, 10 volt divided by 1000 (1K) ohms equals 0.01
amps or 10 milliamps. Power is determined by volts times amps so, 10 times 0.01 equals
0.1 or 100 milliwatts. The output resistors are 250 millwatts to give a time 2 margin of
safety.
The 1K output resistor does form a voltage divider with the 50K input resistance of
module inputs. But this voltage drop is only 2%, and not audible. For precision outputs (1
volt per octave) the 1K resistor is placed inside the op-amp feedback loop. This keeps the
output protection, but the voltage drop is compensated for.
Since all the output are protected by 1K resistors, you can use simple multiples to mix
module outputs together. For example, to place Borg 1 ouptus in parallel, just run the
same signal to both inputs and connect both ouputs to the multiple at the bottom of the
patch bay.
Since every module input and output is fault protected, this means you can connect the
modules without fear to any other type of module. It should be impossible for the Wiard to
do any damage to any other kind of module, and likewise the other modules can not
damage the Wiard modules.
So, it is safe to patch the Wiard 300 or 1200 modules to modules from other
manufacturers.
If you are sending 10 volt outputs to 5 volt inputs, you need a simple attenuator to get the
BEHAVIOR you expect. Take the exaple of a VCA that has a gain of one (unity) at 5 volts.
Without an attenuator, the VCA will "clip" the 10 volt envelope and spend most of it's time
fully on.
Now that I know whats going on, it would be trivial to convert the 1209 Joystick and 1211
JAG module to operate at 5 volts in the native mode. This only involves changing some
resistor values.
This is not the same as changing to banana plugs, which is machanically difficult and
would not produce a "roadworthy" module.
Sorry for any misunderstanding. I deliberately do not look at other modern manufacturers
products so I don't get influenced by trendy ideas. It is easier to be completely original if
you avoid the "pollution" of what is happening now, and just concentrate on sticking to
your own internal vision.
I think the market needs more original thinking and less repackaging of vintage designs.
Just repackaging someone elses design is very inexpensive, because there are no research
and development costs. This is why some people can sell their modules so cheaply, they
have no real investment aside from a faceplate and PC board. This does nothing to
advance the state of the art.
All of Wiard intellectual property is utterly unique, nothing is copied (except on the
conceptual level) from any one else. The goal is to advance the state of the art in synthesis
in general, not just in regards to modular instruments. I think this has worked great in that
regard (although the "cloned" designs may sell more widely).
> Best wishes
> Dieter Doepfer
